I have a number of DVD's on HDD (containing .vob files, etc.) and like to convert those to .iso files.
(with e.g. ImgBurn or DVDFab)
Curious to know...:
will there be any loss of quality, or will the quality be the same, or at least very close to the same, i.e. no noticeable difference.
Oh, btw, I have done a test as to convert a DVD to .mkv using MPEG-2 video stream format (not H.264/AVC).
This resulted in a 4GB file (source was/is 4.6GB)
However, when using H.264 x264 it would result in something like 1.4-1.7GB
So, if space isn't important, I guess MPEG-2 is to be preferred (in case of .mkv).
This is a bit off-topic, I know.
The question was about converting to .iso.
Thanks!
If you simply wrapped the original DVD in a MKV container using MakeMKV, there is no loss or no change in size. So if source is 4.6GB for the whole disc then the resulting MKV files of all the titles on the disc will total 4.6GB approx.
SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
You do not "convert" a DVD to an ISO file; the ISO file is an image of the whole media content, files (VOB, IFO, BUP) as well as the file system (in case of a Video DVD, both ISO-9660 and Micro-UDF) including a directory structure – sector by sector, as if it were burned or pressed onto a physical disc. The file contents will be preserved byte-exact. Thus, quality cannot be degraded.
In addition to the ISO image (especially if you have a DVD-9 with layer break), ImgBurn will also create an MDS file describing the track layout (possibly including the position of the layer break, very important for a DVD-9).
You may then mount this ISO (or MDS) file in a virtual CDVD drive, like e.g. Daemon Tools, and it will appear to the system like you would have inserted a physical disc into a real drive.Last edited by LigH.de; 20th Aug 2018 at 04:44.
DVD Fab - Video Quality Issue going DVD9 to DVD5
By Frank-0-Video in forum Newbie / General discussionsReplies: 7Last Post: 8th Dec 2017, 18:37 -
Bluray to DVD5 or DVD9 to DVD5
By granol in forum Blu-ray RippingReplies: 10Last Post: 28th Sep 2017, 07:57 -
Freeware to compress dvd9 to dvd5?
By Topher5000 in forum DVD RippingReplies: 11Last Post: 27th Aug 2016, 08:49 -
DVD9 to DVD5 with menus, best method?
By Jackpumpkinhead in forum DVD RippingReplies: 15Last Post: 22nd Jun 2014, 14:42 -
Cloned DVD9 Game of Thrones to ISO
By callidus in forum DVD RippingReplies: 13Last Post: 20th Jun 2014, 20:24
