The macrovision hack on the pacific doesn't work, can anyone help?
Thanks.
Not sure what you are doing but try this:
1. Open drawer.
2. Press 9, 8, 1, 7 on the remote control.
3. Press ENTER till region 9 for region free, or regions 1 to 6.
4. Press RETURN.
5. There is also an option in the menu to remove Macrovison and set PAL output.
Hope it works
Cya
Richard StandenI want ADSL.....
1.7Km from BT Exchange (in a straight line)
2.0Km from BT Exchange (by road)
7.8Km of cable laied from BT Exchange to my house... Figure that one out????? -
Tried code you put but no good, you still cant turn macrovision off.
When you open trey and press angle on remote you get macrovision _1.0.
If you press display you get another code come up.
If anybody does get a hack for this pls let us know :evil: as im getting really :cry: off. -
This 9817 code does the multi region but still no joy on the macrovision with the new units (pacific 750). You either can't disable it anymore or there is a new code that no one seems to know yet.
Insignia IS-HTIB102731 hack not working
By Ringmaster in forum DVD & Blu-ray PlayersReplies: 2Last Post: 31st Aug 2009, 19:11 -
Hack for LG LD 750???
By sunnjack in forum Newbie / General discussionsReplies: 1Last Post: 14th Jan 2009, 14:51 -
Region hack not working Coby TF-DVD1020
By srelov in forum DVD & Blu-ray PlayersReplies: 1Last Post: 13th Mar 2008, 22:27 -
need a working region hack!
By cryptix in forum DVD & Blu-ray RecordersReplies: 2Last Post: 24th Jan 2008, 07:45 -
Memorox MVD2040 Hack not working
By gvamp in forum DVD & Blu-ray PlayersReplies: 2Last Post: 20th Aug 2007, 10:02
