  1. I've been capturing video (mainly animation) from VHS and making VCDs. My son is complaining that I have not made chapters, but with Nero or Easy CD Creator the only way I see to do that is to split the MPEG up into multiple files, and with TMPGEnc that could take a really long time.
    Do any of the available authoring or burning tools have a way to just scan through and mark where you want chapters to start? Something simple that won't take all day?
    Thanks for any advice!
    Jul 2001
    Maryland
    unfortunatly, VCD has it's limitations.
    I would just encode each episode of the animation as a sperate track.
    That's what I do
  3. with VCDimager u can add entry points into the XML description to be able to advance to a particle time in the same mpg. Read the manual for details on it otherwise u might make a mpg the plays from the first entry point but later on in the movie say at the end u wanna skip the credits and press next, it will take u back to the 2nd entry point...I dont remember how to do it right now so just check the manual
    http://www.vcdhelp.com/phpBB/viewtopic.php?topic=47918&forum=1&20
    ______________
    r@yjr13
    Now selling audioly and visually challenged coasters, frisbees, and vanity mirrors.
    <font size=-1>[ This Message was edited by: rayjr13 on 2001-07-30 10:39:54 ]</font>
  4. I'll have to look into VCDimager. Thanks!
