i encoded a video but looks like encode made the video bit sharper and losing some dark details. not sure if it's for deblock issue or not. it will be helpful if someone can point me out what causing the issue
screen compare
http://screenshotcomparison.com/comparison/118838
first image (b) encode settings
Encoding settings : cabac=1 / ref=5 / deblock=1:-1:-1 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-4 / threads=22 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=5 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=2pass / mbtree=1 / bitrate=1000 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=62500 / vbv_bufsize=78125 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=1:1.00
second image (a) encode settings
Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=18 / lookahead_threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=5249 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Regarding the brightness problem, you may have a full-range vs. limited range YUV problem. A full range YUV source being interpreted as limited range would cause darks would get darker and brights would get brighter. Your sample doesn't have any brights so I can't tell if that is the problem.
Regarding the image getting sharper, reencoding doesn't cause that. Are you doing some other filtering? And why are re-encoding at 1000 kbps file to a new 5259 kbps? Reencoding can only make the quality worse. -
my bad, actually second image is the original source. original video=a encoded video=b
regarding YUV.. i am not sure what is that. re-encode videomedia info has these info which are not available in main source:
Forced : No
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
may be these are the reason? i used handbrak and i haven't use any filter -
Forced : No
Adjusting video contrast/brightness/sharpness
By cottage in forum EditingReplies: 8Last Post: 22nd Oct 2016, 13:44 -
Sharpness is Handbrake.
By Abdullah in forum DVD RippingReplies: 1Last Post: 22nd Dec 2014, 16:34 -
Megui sharpness help
By kujija in forum EditingReplies: 0Last Post: 16th Aug 2014, 15:14 -
What free app to change cold blue tint and sharpness of video clips?
By Firewire60 in forum Video ConversionReplies: 3Last Post: 15th Jul 2014, 23:05 -
Improve Sharpness
By Vegetto in forum DVD RippingReplies: 1Last Post: 15th Jun 2014, 06:09
