    May 2004
    Brazil
    What's the best way to convert wavpack files to wav?
    Thanks!
  2. foobar2000 will convert any file type it can play, and you can use any command line encoder, but it'll decode wavpack and convert to wav "out of the box".
    Load a file or files into a playlist, select them all (if you prefer), right click and select "Convert", then select the Quick Convert option and choose WAV from the list of encoder presets when the Quick Convert window opens.
    Out of the box, foobar2000 probably looks somewhat fugly, but converting to wav is easy enough.
    May 2004
    Brazil
    Thanks. It worked fine.
