hello guys,
does anyone know a good conversion method (scripts, batches etc would also be ok) if I want to convert a 23,970fps BD50 to a 25fps BD25 ?
The mainmovie on the BD50 has 25,09gb (37,0 mbps bitrate) so it should be 23,90gb (34,78 mbps bitrate) to fit on a BD25.
I tried to shrink it with CloneBD and after that speed the fps up with tsmuxer but that didn't work out so maybe you guys know a way for good real conversion.
Thanks in advance
regards
-Gwar
I know how to do it using a combination of software, i'e. AviSynth, VirtualDub, Vegas Pro, MeGUI, etc.
However, to do it right would take many hours of work. If I'm working on a source that will be viewed in different parts of the world that use different TV standards, I'll go that route. If it's a retail Bluray, I don't see the point in all that work when the correct formats are widely available.
BD50 to BD25 best quality?
By PatrickBatman in forum Blu-ray RippingReplies: 26Last Post: 2nd Oct 2020, 16:06 -
BD50-to-BD50 copy isn't playing
By Tyrexionibus in forum Blu-ray RippingReplies: 15Last Post: 23rd Dec 2015, 09:37 -
23.976>25.000fps video including audio speedup using Mac?
By flexx in forum MacReplies: 3Last Post: 28th Oct 2015, 07:35 -
How to shrink 3D BD50 to BD25
By danswano in forum Authoring (Blu-ray)Replies: 20Last Post: 23rd Oct 2013, 08:19 -
BDtoAVCHD made BD25 conversion too large for BD25 media
By AUTOBOT in forum Authoring (Blu-ray)Replies: 11Last Post: 20th Oct 2013, 18:03
