I am in need of a free video converter that will let me convert WMV format videos to either Cinepak or Video 1 encoded AVIs.
Can someone help?
VirtualDub2. But Cinepak and MS Video 1 are far outdated and slow. There are much better choices if you don't specifically require them.
Thanks! If you're wondering, I needed to convert to Cinepak or Video 1 so I could import some videos into Adobe Premiere 5.0 (which uses those formats) to make a video.
It may be not best from your perspective but it should work - modified one of my scripts but not tested after modification. Framerate conversion may not work best due a way how ffmpeg perform framerate conversion - perhaps adding small motion blur may keep perceived smoothness, there is crude antialiasing but IMHO it gives decent visual results and that's why i use it almost as a mandatory for low res video.Code:
@setlocal @set FF=C:\FFmpeg @set PATH=%FF%;%PATH% @set filename=%~1 @rem video quality settings @set vq=32 @set fps=25/2 @set vproc="pp=ac,pp=ac,pp=ac,hqdn3d=5,eq=contrast=256/220:brightness=1/512:saturation=256/224:gamma=16/16,scale=320:-4:sws_flags=spline+accurate_rnd+full_chroma_int+full_chroma_inp,minterpolate=fps=%fps%:mi_mode=mci:me_mode=bidir:me=ntss:vsbmc=1,xbr=2,scale=320:-4:sws_flags=spline+accurate_rnd+full_chroma_int+full_chroma_inp:sws_dither=2:in_range=0:out_range=2,format=pix_fmts=rgb24,pad=320:240:(ow-iw)/2:(oh-ih)/2" @set aproc="pan=mono|FC < 1.414FC+FR+FL+0.5BL+0.5SL+0.25LFE+0.125BR,firequalizer=gain='if(gte(f,25),0,-INF)+if(lte(f,11024),0,-INF)',dynaudnorm=p=1/sqrt(2):m=100:s=20,firequalizer=gain='if(gte(f,25),0,-INF)+if(lte(f,11024),0,-INF)',aresample=resampler=soxr:osr=22050:cutoff=0.990:dither_method=shibata" @rem ffmpeg.exe -hide_banner -v 32 -stats -y -i "%filename%" -vf %vproc% -c:v cinepak -q:v %vq% -af %aproc% -c:a pcm_s8 -f mov "%~n1_.mov" @ffmpeg.exe -hide_banner -v 32 -stats -y -i "%filename%" -vf %vproc% -c:v cinepak -q:v %vq% -af %aproc% -c:a pcm_u8 -f avi -dn -sn "%~n1_.avi" @endlocal @pause @exit
If you search forum there is dedicated thread to cinepak.
Btw i doubt that you need to use cinepak or msvideo to use Adobe Premiere - for sure uncompressed video will work way better than crude lossy compressed video. Cinepak compression is last step process at the end of normal signal chain - target for computers where processor have usually less than 10MIPS.Last edited by pandy; 18th Aug 2018 at 07:51.
Lagarith and UT Video Codec work with VirtualDub, and I believe, Premiere. Those are much better choices for intermediate files. The old Huffyuv is also a good choice for 32 bit Windows. Cinepak sucks. MS Video 1 at its highest quality is better but will give a lot of posterization.
I guess the reason why Premiere 5 seems to require such outdated codecs is that only these outdated codecs are currently installed in Windows. If you install more modern VfW codecs, Premiere 5 will support them too, using the VfW interface. It just relies on Windows here.
MKV2MP4 not including subs when converted
By Acker-Z in forum SubtitleReplies: 1Last Post: 27th Jul 2017, 18:10 -
How to keep 2 audio collections in sync -- when 2nd is converted format?
By jimssupp in forum AudioReplies: 0Last Post: 13th Mar 2016, 17:54 -
What could be the problem behind this converted video?
By Unknown01 in forum Newbie / General discussionsReplies: 5Last Post: 18th Oct 2015, 19:56 -
SubPics Converted to Images
By sambat in forum SubtitleReplies: 4Last Post: 2nd Apr 2015, 11:22 -
[updated] Getting VC-1i ready to be converted
By leghorn in forum Blu-ray RippingReplies: 0Last Post: 27th Sep 2013, 18:09
