Hi, I have some very large (8-12GB) .mkv 4K video files that I'd also like to have 1080p copies of. So I have a few questions:
1. Which will look better, native 1080p or 4K down-sampled/down-scaled to 1080p? Should I even bother down-scaling, or should I try to find native 1080p copies?
2. What is the best way to go about down-scaling/down-sampling these files to 1080p? What software/settings/methods should I use?
3. Finally, as I'd still like to keep them, what is the best way to losslessly compress those large 4K video files so that they don't take up as much space?
Thank you so much for answering any of these, it's really helpful. Hope you all have a wonderful day!![]()
8 - 12GB for 4K video doesn't sound particularly as lot of space nowadays. Real 4K downscaled to 1080p will be usually better than native real 1080p but usually your 1080p will be produced by downscaling source used to create 4K video. Generally it is way better to use higher resolution to create lower resolution target.
Best way to compress large Video Files (HandBrake, MP4)?
By user115 in forum Video ConversionReplies: 21Last Post: 17th Dec 2018, 10:04 -
How merge X video files without opening video compression (it possible ? )
By yanshof in forum Newbie / General discussionsReplies: 9Last Post: 29th Dec 2017, 17:07 -
Video conversion/compression suggestions
By ShadowWizard in forum Video ConversionReplies: 10Last Post: 19th Jun 2017, 15:52 -
Good method/workflow for Video Conversion for multiple devices
By dellhop in forum Video ConversionReplies: 7Last Post: 12th Mar 2017, 14:03 -
New Compression Method
By Tom Saurus in forum Latest Video NewsReplies: 8Last Post: 16th Apr 2015, 04:49
