Hi Folks,
I am a rookie who is stumbling through Divinci Resolve and watching "how to "videos on youtube. I record comedy shows of my students then send them to them.
Currently I have an MP4 - recorded on my Panasonic HV750 handy cam, which is 6GB large. It is obviously to big for most file sharing platforms.
Google Drive wont play it saying its processing. My question is how do I use the rendering settings on divinci to reduce its size and quality so I can easily send this file to my students or host it on youtube. I have attempted this a couple of times already, but something isnt right - it keeps saying its going to take 9hrs to complete!!! A normal download of this file takes 2 hours so I can't understand this. Plus if this is just how it is, then it makes the process totally unsustainable. I'm eager to hear if there is anything I can do, any help appreciated!
James
NZ
I can't help you specifically with Resolve, but...
There's nothing unusual about that. Re(rendering) takes time. Use faster compression settings for faster encoding. With some codecs there can be a 100 fold difference in encoding speed depending on the settings. Generally, the slower the encoding the better the quality.
Use a lower bitrate for a smaller file size. So if your source video is 20 Mb/sec and you re-encode at 5 Mb/sec you will get a file that's about 1/4 the size. If you use too low a bitrate quality will suffer. One way to counter that is to reduce the resolution, say from 1920x1080 to 1280x720 or 960x540. When you do that you are trading away resolution to get better quality of what's left. -
Thanks for the feedback, I have checked the settings and I'm currently rendering at 5mb per second, 720p. So for now I guess it's just patience.
Cheers -
Encode video without losing quality and retaining file size
By thinredline in forum Video ConversionReplies: 3Last Post: 23rd Oct 2014, 08:33 -
Add logo or watermark quickly without affecting video file size or quality
By MGadAllah in forum EditingReplies: 29Last Post: 27th Jul 2014, 10:38 -
no render information in video file
By moinsen1974 in forum Newbie / General discussionsReplies: 11Last Post: 29th May 2014, 01:57 -
Converting AVCHD video to smaller size
By recordrecorder in forum Video ConversionReplies: 4Last Post: 7th Nov 2013, 16:08 -
[Q] Blu-ray to MKV to MP4... How to keep HD and smallER file size
By Varxtis in forum Blu-ray RippingReplies: 6Last Post: 27th Sep 2013, 19:15
