Hi,
I use mkvmerge to merge a x264, dts and sup file. The mkv file plays fine in vlc player with the subs in the expected position. If i play it in PowerDVD (17), the subs are positioned according to the default subtitle position specified in powerdvd's settings ie. at 6% from the bottom. This is not good as it means having to change this setting for different aspect videos files.
Same think happens when i create my own sup file (using SubtitleEdit) with position height specified in the sup file.
Does anyone know how i can get the file to save the subtitle position in the file so it plays in the correct place every time no matter what player is used. Ideally i'd rather this were a setting in the file than re-encoding to hard subs. Of course there was no issue with using BD or AVCHD structures, but i want to simplify my files to just mkv now.
thanks
asianhawk
Maybe if you used SSA/ASS Subtitles https://www.matroska.org/technical/specs/subtitles/ssa.html it would work. I only use an external media player for my video's and you can control the position in it's hardware.
Cutting MKV Files - Subtitle Files Inside of MKV
By devilcoelhodog in forum EditingReplies: 2Last Post: 11th Sep 2016, 22:29 -
.ts DVB with dvbsubtitles --> mkv with subtitles (wrong subtitle position)
By smellycat3 in forum Video ConversionReplies: 2Last Post: 27th Dec 2015, 17:45 -
PGS time/time position after merging MTS files to MKV
By MrRalph in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 4th Aug 2014, 14:50 -
I want your help: Change subtitle position
By mmkk in forum SubtitleReplies: 2Last Post: 31st Jan 2014, 18:35 -
Subtitle position not working...
By djluis48 in forum SubtitleReplies: 2Last Post: 22nd Aug 2013, 10:51
