If I do a capture and accidently let the record go past the intended segment, how do I cut and remove the unwanted segment? Using tmpgenc's mpeg tool it has to "pull" the part that I want (large) rather than the part I don't want (small). Am I missing something? Sorry for such a basic question, I've looked at all the tools and looked for a post that addresses this issue to no avail. Thanks, Andy
Since you are doing a capture, I'm assuming that your files are MPEG2. To cut MPG files, you can use TSMPG's "Files" > "MPeg Tools" > "Merge/Cut". However, while it does make cuts on only the "I" frames (the beginning of a GOP, the only place you should cut on MPEGs), it is virtually impossible to make a cut where you want it using the interface (it also doesn't cut where you want it). I don't know why this happens, but with large files (>1 GB), the cut feature is virtually worthless. Smaller files might be okay, but this hasn't worked for me.
Possible To Make A VDub Script To Cut Segment From Video?
By onesikgypo in forum ProgrammingReplies: 1Last Post: 17th Jun 2011, 20:02 -
What program to cut out unwanted sections of DV-AVI for archive
By piperpilot12w in forum EditingReplies: 6Last Post: 30th Aug 2010, 00:52 -
Please recommend a tool to cut a segment out of a larger video file...
By alank2 in forum Newbie / General discussionsReplies: 16Last Post: 25th Jan 2010, 14:11 -
DVD FLICK- ending cut off
By sheftic in forum Newbie / General discussionsReplies: 1Last Post: 8th Sep 2009, 01:29 -
AVCHD viceo with .MTS ending cannot be read by Quicktime/ final cut express
By johsch in forum ffmpegX general discussionReplies: 10Last Post: 26th Nov 2008, 14:01
