hi, sorry for my bad english,
i have download this documentary video from the internet (now the video in my pc harddisk),
the video is TS file, the quality of the video is about 8/10, the file size is about 120mb, the average bit rate is 498 kb/s, 638 x 362 pixels, 33 minutes
now the problem, the TS is good, but when i like to slide the time duration bar (i don't know what it called) or move to 5 / 10 second forward / back, the video player is "buffering" some file only 1 or 2 seconds, but another file can be above 10 second, i hate this,
because of that, i like to convert it, i have tried many converter software, but the result is quite disappointing, it can be same quality but the size is huge, it almost over 1.5gb, another trick i use handbrake 2 pass but the results size is 3x times, about 310mb file, plus it takes a lot of time, about 45 minutes, i think i will avoid this in the future
the condition that i want is, the file size and quality is relative same, but the "buffering" is gone,
if you all have any trick to do this thing?, please help
Post a MediInfo file report of the file. Possibly what you could do is use MakeMKV to wrap it in a MKV container, it would be the same size and maybe navigate better in your player
SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
this is the source mediainfo
i use media player classic media info, i don't know if it will help,Code:General ID : 1 (0x1) Complete name : C:\delete me\how to smith.TS Format : MPEG-TS File size : 121 MiB Duration : 33 min 53 s Overall bit rate mode : Variable Overall bit rate : 498 kb/s Video ID : 256 (0x100) Menu ID : 1 (0x1) Format : AVC Format/Info : Advanced Video Codec Format profile : Main@L3 Format settings : CABAC / 1 Ref Frames Format settings, CABAC : Yes Format settings, ReFrames : 1 frame Format settings, GOP : M=1, N=50 Codec ID : 27 Duration : 33 min 53 s Nominal bit rate : 370 kb/s Width : 638 pixels Height : 362 pixels Display aspect ratio : 16:9 Frame rate : 25.000 FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.064 Writing library : x264 core 148 r236 a01e339 Encoding settings : cabac=1 / ref=1 / deblock=1:-1:-1 / analyse=0x1:0x111 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-1 / threads=2 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / stitchable=1 / constrained_intra=0 / bframes=0 / weightp=0 / keyint=50 / keyint_min=5 / scenecut=0 / intra_refresh=0 / rc_lookahead=50 / rc=2pass / mbtree=1 / bitrate=370 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=500 / vbv_bufsize=500 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=1:1.00 Audio ID : 257 (0x101) Menu ID : 1 (0x1) Format : AAC Format/Info : Advanced Audio Codec Format version : Version 4 Format profile : LC Muxing mode : ADTS Codec ID : 15 Duration : 33 min 52 s Bit rate mode : Variable Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 44.1 kHz Frame rate : 43.066 FPS (1024 SPF) Compression mode : Lossy Delay relative to video : -23 ms Menu ID : 4096 (0x1000) Menu ID : 1 (0x1) Duration : 33 min 53 s List : 256 (0x100) (AVC) / 257 (0x101) (AAC) Service name : Service01 Service provider : FFmpeg Service type : digital television
for the results the1.5gb and 310 mb, i have deleted it -
Download MKVtoolnix and put the .TS file into a .MKV. I don't think .TS has any kind of indexing of files so it can take a long time before a new GOP starts, allowing it to play. Muxing into MKV should take only a few seconds.
No problem - I've been doing it for years - all my TS files of my PVR to MKV and DVD's and Blu ray. So far no problems. Any tracks within the resultant MKV file can be unticked in MKVToolnix and then remuxed.
