The DVD drive in this model is a TS-P632F/SDAH and seems to be unobtainable / obsolete. As it seems videos on the HDD can only be copied off via DVD I’m stuffed unless one of you guys know where I can get one.
Alternatively know of other machines that use the same DVD Drive that I could use.
Many thanks
John.
There are a handful of these type of recorders, that you can remove the HDD and hook it up to a computer to copy the recordings.
It's highly doubtful that this Samsung unit does not use proprietary software to "encrypt" the recordings....but if the HDD looks like
a normal HDD....you may want to give that a try.
I own a Medion/LG recorder that I occasionally use this way. It does require special software but the software is tiny and trouble free. -
Many thanks hech54 but tried that. One of the folders called Clips has all the Videos but they can't be copied or opened despite using all the know unlocking apps. It seems the only way to transfer the videos to my pc is either a replacement DVD unit, fitting the HDD in a compatable system or with a loss of res via a video graber hooked from the HDMI out to USB in on my PC - unless anyone can thing of another way. PS. What is that software you used?
These are the three LG/Medion HDD reader softwares that were available for the recorders of yesteryear.
https://mega.nz/#F!0dpXzQTL!b2XPHRKh3FpyRKdnNfsSGQ -
I'm on XP Pro.....they run fine for me....but only one is necessary.
I've got an XP Pro system so I'll give that a go
Many thanks for all the help
John.
Help wanted with making untouched uncompressed DVD copies. (DVD TV Series)
By SE14man in forum DVD RippingReplies: 13Last Post: 14th Apr 2018, 20:23 -
I cannot convert my old tv series files to work properly on a Samsung HDTV
By TV Addict in forum Video ConversionReplies: 8Last Post: 30th Mar 2017, 18:55 -
Samsung writer won't reinstall, not supported by Samsung
By blacktooth in forum DVD & Blu-ray WritersReplies: 4Last Post: 11th Jan 2017, 23:47 -
Do DVD boxsets of TV series ever use forced subtitles?
By osullic in forum SubtitleReplies: 2Last Post: 27th Mar 2015, 00:43 -
DVD with multiple titles (TV series) has episodes in wrong order.
By Ole_thor in forum DVD RippingReplies: 2Last Post: 13th Nov 2013, 23:29
