Results 31 to 43 of 43
Looking good, this really that seems much more effective
Code:LSmashVideoSource("Sample-1986 Supercross Bercy.mp4") Spline36Resize(width/2, height) MergeChroma(RemoveDirtMC(100).TNLMeans(ax=4, ay=4, az=4, h=6).aWarpSharp(depth=20)) TemporalDegrain(SAD1=100, SAD2=75, sigma=4) SmoothTweak(saturation=1.3) Santiag() aWarpSharp(depth=5) Sharpen(0.3,0.0) nnedi3_rpow2(2, cshift="SPline36Resize", fwidth=width*2, fheight=height)
I think if you start with KNL,
and end with the script from jagabo (but with some of the settings tuned down),
the end product will be better than what either of us did.Want my help? Ask here! (not via PM!)
FAQs: Best Blank Discs Best TBCs Best VCRs for capture Restore VHS -
You need to find a better shot to get a more accurate reading. But if that shot is nearly square pixel, just cropping away the black borders leaves you with 698x466, very close to 3:2. Resizing to 680x466 to the wheel a little more round, gives about 1.45:1.
Hi guys, I am new to this forum, and I am not an expert in Avisynth usage, but I would like to learn new things. My problem is similar to that in Caiosouza's first video, but when I write in AvsPMod MergeChroma(TemporalMedian(2)) it writes there is no function named TemporalMedian, and I can't find it in Avisynth external filters' page (http://avisynth.nl/index.php/External_filters#Spatio-Temporal_Denoisers). Where can I find that function? Regards
I found it
https://forum.videohelp.com/threads/362361-Median%28%29-plugin-for-Avisynth
Anyway, can I post my video? It includes a lot of noise as well....Or should I start a new thread? -
1- setup Avisynth correctly, including all used filters in the script
2- KNL needs x64, and that Avisynth+ x64 is suggested
3- AvsPmod must also be the x64 version.Want my help? Ask here! (not via PM!)
