Hi,
mpeg and 4k files to edit, scrub frame by frame fwd and backward, adjust sound volumes, multi tracks for vid and audio, easy separation of original audio from vid, exposure controls.
ability to export the 4k as HD.
intuitive, easy to get up and running. I have used premiere pro CS6 so not a beginner as such, but only done simple work, lay in music track, fades etc. I dont want to pay subs else I might upgrade to cloud.
what prog would be best for 4k and mpeg editing ?
Dbenz
Vegas Pro.
You might be able to get by with the Studio edition but it may not support 4K. Check it out.
You can do this stuff on the cheap, but need to learn the different utilities like AviDemux. AviDemux can transcode from 4K to HD, and it's free. Then you can edit the HD in any cheap editor.
"Intuitive" is the best description of Vegas. It's mostly used by wedding videographers. It's every bit as pro as Premiere.
Mpeg is my favorite editing codec too.
You can also consider 2K.Last edited by budwzr; 14th Aug 2018 at 17:11.
Hi,
sounds good, one problem the price I dont have $600 . blast !
I can stretch to £100 though , at expense of things screaming out to be fixed.
Merlin -
Jeezus, it's $600 now?
Hey, man you're gonna have to go for the $100 softwares.
The options are getting depressing here lately. Learn AVIDemux.Last edited by budwzr; 14th Aug 2018 at 18:33.
Hi,
Catching up on my quest for an intuitive affordable video editing prog, I google AVIdemux and I am taken now to NCHsoftware Video Pad Video Editor with a free version for domestic use.
I try again and get sourceforge avidemux.
others I downloaded at the time are:-
Vegas Movie Studio 15 platinum trial 16aug2018
Video editor power director 16 trial 16aug2018
video editor magix movie edit pro plus trial 16aug2018
so these four and also avidemux and now also VideoPad video Editor...
I have 4K footage from my camcorder I wish to cut unwanted segements from then create a final 4K video file for playing on my PC.
I also need do de-interlace a few recordings to see if I can lose the haircomb effect that way.
I have .mpg files to edit and save as .mpg
I have mp4 files to edit and save as mp4 or mpg, whatever is best.
Is AVIdemux the one to do all this for me ?
Cheers
DBenzLast edited by DBenz; 24th Jul 2019 at 16:19.
You might look at Vegas Movie Studio 16 Platinum for improvements over Vegas Movie Studio 15 Platinum: https://www.vegascreativesoftware.com/gb/vegas-movie-studio/?_oB=movie-studio-platinum
The web page for Vegas Movie Studio 16 Platinum indicates that it can edit 4K and can export 4K XAVC S video and it supports HEVC import and export.Last edited by usually_quiet; 25th Jul 2019 at 12:20. Reason: clarify 4K editing & formats ...and correct typo
Need a simple video editor/encoder software
By meis in forum Newbie / General discussionsReplies: 1Last Post: 4th Mar 2018, 22:45 -
Video editor software suggestion
By ShadowWizard in forum EditingReplies: 7Last Post: 10th Jul 2017, 21:24 -
video editor software
By kj1983 in forum EditingReplies: 16Last Post: 18th May 2017, 22:18 -
Is end result mostly dependent on editor software or codecs?
By larioso in forum EditingReplies: 16Last Post: 31st Dec 2016, 15:49 -
Is fastest rendering software AVS Video Editor?
By johnharlin in forum Video ConversionReplies: 8Last Post: 19th Nov 2016, 10:49
