I have the opportunity to purchase a Hauppauge HD PVR with a model No 49001PF. I am not aware of its age. Is this suitable for me to use to convert my (PAL).8mm/Hi8 camcoder tapes using my sony Digital8 camcorder. I have a firewire card installed on pc.
Advice would be appreciated
It depends on the tape quality.
- If it needs restoration, not greatest quality, go lossless with capture card.
- If quality, then good Digital8 for Hi8/Video is passable.
Note that this advice is PAL only. The NTSC 4:1:1 is brutal, loses 50%+ color quality on the transfer.Want my help? Ask here! (not via PM!)
Note that the Hauppague HD-PVR is incapable of lossless capture. It has a built-in encoder chip and sends H.264 video and AC3 audio to a PC via its USB 2.0 connection. Lossless capture requires a device which outputs uncompressed digital video and audio and uses software running on a PC to encode the video and audio.
Ignore list: hello_hello, tried, TechLord, Snoopy329 -
Also, the Hauppauge HD-PVR series is prone to locking up (requiring a power cycle of the HD-PVR) with bad time base -- especially when fast forwarding or rewinding.
If you have other uses for it (HD capture) it's ok. But for VHS/V8/Hi8 it's a waste of money. Your PAL DV camcorder with it's built in TBC will give you much better results than the HD-PVR. -
Thank you for your responses. From your comments, I've decided against the Hauppauge.
Some years back, I purchased the Sony DCR-480E camcorder mainly to use as passthrough for my 30 or so 8mm analogue tapes, from my Yachica(Kyocera)8 camcoder. While the video captured is acceptable, unfortunately, the audio has interference, is distorted and unusable. However, capturing direct from the Sony Digital8, both video and audio are acceptable, considering the content was recorded on 8mm tape. In the Sony Handbook, the method for capturing from external VCR devices for digital conversion, is via firewire to the capture software. I don't know if by capturing the 8mm analogue tapes directly from the Sony, converts to digital. I am going to experiment by capturing from the Sony also from the Yashica(vision only) to compare. It is from the feedback you have provided that has prompted me to try this (should have thought of it myself).
Any thoughts or further advice would be welcome. -
Much relieved to read your very welcome quick response 'jagabo' as I've just b------d my Yashica.
I've been wrestling with the issue of conversion for some while now searching for answers obviously didn't find the right one, until now.
Thanks aslo to 'usually_quiet' for the same answer, which I missed.
Hauppauge Capture Software editing
By GSP_87 in forum EditingReplies: 5Last Post: 5th Sep 2017, 22:40 -
Hauppauge PVR2 - audio sync issue with Hauppauge Capture -- alternative?
By texas1 in forum Capturing and VCRReplies: 35Last Post: 2nd Apr 2017, 02:27 -
Hauppauge PVR150 Capture Question
By ftv37 in forum Capturing and VCRReplies: 3Last Post: 10th Jan 2015, 23:47 -
Hauppauge HD PVR goes into hibernate during capture
By the Devil in forum Capturing and VCRReplies: 1Last Post: 12th Mar 2014, 08:31 -
Hauppauge Colossus HDMI capture
By prolific in forum Capturing and VCRReplies: 0Last Post: 15th Feb 2014, 10:52
