Hi! I am new to VideoHelp and new to Avisynth.
I'd like help on knowing how to filter anime like this.
https://www.youtube.com/watch?v=sw8uC1xxcEw
https://www.youtube.com/watch?v=LGQCPOMcYJQ&t=1s
The lines look pretty sharper and much detailed there.
BTW, I am sure this is really filtered hence the HD remaster and the Blu-Ray don't look like this.
Thanks for any help in advance!
Results 1 to 12 of 12
Both are blocked in my country (US). Surely you're not planning on trying to restore some garbage you got from YouTube? You have your own copies of the DVD or Blu-Ray?
@manono The video is in HD. Try using a proxy, (I do have dvdrips)
Screenshots of the videos:
http://prntscr.com/khsbre
http://prntscr.com/khsbtq
http://prntscr.com/khsc1w
https://prnt.sc/khsc70 -
What country?
Upload a sample from your DVD. You can use DgIndex to mark a representative segment and demux it as an M2V file.
Those screen shots are terrible. They're way oversharpened and have no real detail. -
Any country besides USA.
This one might look better. https://www.youtube.com/watch?v=NjWRPlK7Tqk The edges are more detailed there. (This was on my bookmarks from ages ago so it's unlisted.)
Also, DVD-Rips. Not DVDs.
Sample (I had this already cut in my PC) https://mega.nz/#!Mf5nDYCI!AXHyD9dcr3UmSK-S5V3otC4QwU7LDyRBeZ6rj5WYIH4 -
DVD is not HD. It's either DVD or HD. Can't be both.
DVD is never AVC encoded, dude. DVD is MPEG only.
So your sample isn't a DVD rip. it's a re-processed and lossy re-encode from another source. And the frame rate is a little off (23.956 fps ??).
Other than the usual lossy degradation, what's the problem? Restore the sample to what format?Last edited by LMotlow; 12th Aug 2018 at 21:55.
- My sister Ann's brother -
No thanks.
He's using DVDRip in the warez sense. It started out as a DVD and someone else reencoded it and uploaded it and he then illegally downloaded it to try ... what? "Restoring" it when he knows next to nothing about AviSynth?
So, I tried downloading the much-too-large sample and after 87MB:
"[Exception... "Out of Memory" nsresult: "0x8007000e (NS… "
This has become more trouble than it's worth. I pass. -
The download took a few minutes and was 347MB. Oddball frame rate (23.952 fps) oddball audio sampling (96KHz). When smart rendered with VideoReDo or TMPGenc the whole business totals 83MB instead of 347MB (???).
Attached is the first half of the jumpy download I got, smart rendered with TMPGenc, and a .txt MediaInfo report on the original 347MB download for comparing. How many times is Sailor Moon going to make the rounds?- My sister Ann's brother -
Levels adjustments, mild white balance, temporal noise reduction, deshake, upscale, sharpen, etc. The deshaking isn't very effect because of the way different parts of the picture move differently (bad deinterlacing? bad film transfer?), you might be better off without it. The string temporal noise reduction will likely cause problems in panning shots with low contrast detail.
HD is the youtube video. Not the DVD.
Oh my god that looks absolutely gorgeous. - I have right now tried to do the same! Thanks for the tips!Levels adjustments, mild white balance, temporal noise reduction, deshake, upscale, sharpen, etc. The deshaking isn't very effect because of the way different parts of the picture move differently (bad deinterlacing? bad film transfer?), you might be better off without it. The string temporal noise reduction will likely cause problems in panning shots with low contrast detail.
The script I used:
Starting with the original DVDs should give better results (and will likely require different settings).Code:LSmashVideoSource("Preview.mp4") ConvertToRGB(matrix="PC.601").RGBAdjust(r=0.92).ConvertToYV12(matrix="PC.709") # white balance, left a little warmth ColorYUV(cont_y=35, off_y=5, cont_u=30, cont_v=30) # levels and saturation adjustments dehalo_alpha(rx=2.5, ry=2.5) # halo removal TemporalDegrain(SAD1=200, SAD2=150, sigma=8) # noise reduction #Deen() # alternate noise reduction, needs tuning Stab(range=8, mirror=15, dxmax=1, dymax=1) # deshake Dup(blend=true, threshold=3) # make near duplicate frames exact duplicates (attempt to remove some shaking) MergeChroma(aWarpSharp(depth=5),aWarpSharp(depth=15)) # sharpen luma a little, chroma more nnedi3_rpow2(2, cshift="Spline36Resize", fwidth=960, fheight=720) # upscale partially aWarpSharp(depth=5) # sharpen Sharpen(0.3) # sharpen nnedi3_rpow2(2, cshift="Spline36Resize", fwidth=1440, fheight=1080) # upscale more aWarpSharp(depth=5) # sharpen Sharpen(0.5) # sharpen ChromaShift(c=2) # align colors better
MeGUI + AviSynth 60 FP Anime Help
By SimplyDex in forum Newbie / General discussionsReplies: 20Last Post: 25th Mar 2018, 05:15 -
[AviSynth Help] Fixing interlaced frames in an anime video.
By SUP3RDeathStar in forum Newbie / General discussionsReplies: 0Last Post: 21st Dec 2017, 18:39 -
help upscaling anime 480p to 720p with Megui and avisynth
By zanzar in forum Newbie / General discussionsReplies: 7Last Post: 5th Feb 2016, 13:39 -
Avisynth - Anime Blu-ray with downscale fails
By Ninelpienel in forum EditingReplies: 15Last Post: 26th Aug 2015, 17:06 -
Help restoring this Grainy Anime Source..
By RazorBurn in forum RestorationReplies: 3Last Post: 10th Jan 2015, 14:26
