I previously used DVDFlick to burn a MP4 file of my 60 minute documentary. It turned out just fine. I didn't change any settings, and followed the guidelines on their site. I didn't use any other program to do the burning part, like ImgBurn, for example. This was 5mths ago.
Needed to make more copies of my film now, so I open up the DVDFlick, used all the same settings to try to burn it to DVD. It comes out sideways. Tried different settings, but still sideways. I tried the DeVeDeNG app instead, but it still turns the file sideways. I tried ImgBurn, still sideways, and sometimes it is only a menu screen, with non-clickable play button. I tried 4:3 instead of 16:9. In DeVeDeNG, I used the option to turn the video 90 degrees, but it remains sideways anyway. No change.
I am really mystified because it worked perfectly well months ago, and I haven't changed computers or done anything of significance to my system. Does anyone have any idea how to fix this?
Do a disc-to-disc clone (or disc-to-ISO rip).
Likely your settings are NOT the same, unless you originally saved them (and the assets) and are just re-opening.
Scott -
I didn't change any settings in the first place for anything. They were default settings. So, there is no "likely the settings are NOT" the same.
Turning video into data
By Lindum in forum Newbie / General discussionsReplies: 5Last Post: 17th Sep 2017, 08:53 -
Turning video from VFR to CFR without re-encoding?
By yetanotherlogin in forum EditingReplies: 3Last Post: 29th Aug 2016, 10:09 -
Turning TBC off in favor of Video Calibration.
By digicube in forum RestorationReplies: 19Last Post: 18th Dec 2015, 23:28 -
New, need help turning song to video.
By Kimberly Hargis in forum Newbie / General discussionsReplies: 12Last Post: 12th May 2015, 08:37 -
Vertical stripes of video shifted / displaced sideways in regular pattern
By JonathanCMH in forum Newbie / General discussionsReplies: 26Last Post: 3rd May 2015, 19:58
