I need a really good program to split avi files.
Avi chop is the best thing that I have ever seen. BUT, it does not work with XP.
I tried the FX splitter, but I hate that program. It seems to take forever. When I finally found the progress bar, it had barely moved in over an hour.
Please help. There must be a simple avi splitter out there that works with windows XP and that is not that fx splitter program.
Results 1 to 10 of 10
Yes, I have actually. But, I kept getting great first half copies, but the second have was always messed up.
Ill give it another try and can be more specific if I run into trouble. -
For $75, I purchased Pinnacle Studio 7: it chops and merges .avi files. 8)
*Windows XP Home w/NTFS
*Soyo DRAGON Plus
*Athlon XP 1700+ OC’d
*ALPHA PAL8045U
*Kingston 256MB PC2100
*WD 400BB 7200RPM, 40GB, Qty 2 for RAID 1
*WD1200BB 7200RPM, 120GB
*TDK 24/10/40 VeloCD
*3dfx Voodoo3 2000 w/16MB -
Tmpgenc can merge and cut mpeg files. Go to File > MPEG Tools > the Merge & Cut tab.
roll1time
Dont use VDub to Split Avi's Use Nan Dub.
http://www.nandub.org/
Takes approx 2mins works 100% everytime.
Gabest MP4 splitter vs. Haali Media Splitter
By jaduvil in forum Software PlayingReplies: 4Last Post: 16th Jun 2010, 11:57 -
Avi Splitter which does not show video
By rock99 in forum EditingReplies: 1Last Post: 12th May 2010, 09:15 -
AVI Splitter
By rock99 in forum EditingReplies: 1Last Post: 21st Feb 2010, 12:26 -
free avi splitter
By pwig in forum EditingReplies: 4Last Post: 17th Feb 2009, 05:30 -
avi/mpg splitter
By MasterThomasMI in forum EditingReplies: 3Last Post: 10th Nov 2007, 10:44
