Hi Forum! I'm having trouble with my TV playing mkv files from an HDD.
My TV is a Samsung UN46F6800AG.
The mediainfo of one of the problematic mkv will be pasted at the end.
The thing is that for some unknown reason, whenever I try to play this file, my TV freezes and then reboots. To be specific, I don't even have to play the video; pressing info on the file or just staying (for ~10 sec.) in the directory where its sitting has the same outcome. This doesnt happen with other mkv files (mediainfo of a title that works can be found at the end) I try to play. What strikes me is that I dont think it has anything to do with codecs, since it doesnt show any codec related error. I have tried playing it from another flashdrive, but still the same outcome.
What is the cause? How can I Fix this? All help will be appreciated.
Thanks in advance,
Schlotty.
PS: Posted this on Video Conversion since I believe the problem lays in the format of the problematic file.
Mediainfo
Video that works:
Problematic File:General
Unique ID : 317458531438267167283045079714692078574 (0xEED44A07B03A6DDD911FF413DDB81BEE)
Complete name : Children Who Chase Lost Voices from Deep Below.mkv
Format : Matroska
Format version : Version 4 / Version 2
File size : 1.70 GiB
Duration : 1h 55mn
Overall bit rate : 2 100 Kbps
Movie name : Temporuss Animes Blog
Encoded date : UTC 2017-05-09T10:02:23Z
Writing application : HandBrake 1.0.7 2017040900
Writing library : Lavf57.7.2 / Lavf57.7.2
Video
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 55mn
Nominal bit rate : 2 000 Kbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.040
Writing library : x264 core 148 r2708 86b7198
Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=2000 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=62500 / vbv_bufsize=78125 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=1:1.00
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio
Format : AAC
Format profile : LC
Codec ID : A_AAC
Duration : 1h 55mn
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Frame rate : 46.875 fps (1024 spf)
Compression mode : Lossy
Delay relative to video : -21ms
Title : Stereo
Language : Japanese
Default : Yes
Forced : No
General
Unique ID : 222851701760237975230410143106385080586 (0xA7A7AD32E3D648B99EA7925CC760710A)
Complete name : 5 Centimeters Per Second.mkv
Format : Matroska
File size : 3.18 GiB
Duration : 1h 2mn
Overall bit rate : 7 247 Kbps
Movie name : lleur 2016
Encoded date : UTC 2017-08-08 22:25:40
Writing application : mkvmerge v14.0.0 ('Flow') 64bit
Writing library : libebml v1.3.4 + libmatroska v1.4.5
Video
Format : AVC
Format profile : High 10@L5
Format settings, ReFrames : 8 frames
Duration : 1h 2mn
Bit rate : 6 564 Kbps
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.132
Stream size : 2.88 GiB (91%)
Writing library : x264 core 148 r2665 a01e339
Encoding settings : cabac=1 / ref=8 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=8 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=230 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=crf / mbtree=0 / crf=17.2 / qcomp=0.75 / qpmin=0 / qpmax=81 / qpstep=4 / vbv_maxrate=40000 / vbv_bufsize=40000 / crf_max=0.0 / nal_hrd=none / filler=0 / ip_ratio=1.40 / pb_ratio=1.30 / aq=3:0.90
Language : Japanese
Default : Yes
Forced : No
Audio
Format : AC-3
Format/Info : Audio Coding 3
Format settings, Endianness : Big
Codec ID : A_AC3
Duration : 1h 2mn
Bit rate mode : Constant
Bit rate : 640 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Frame rate : 31.250 fps (1536 spf)
Stream size : 287 MiB (9%)
Language : Japanese
Default : Yes
Forced : No
Text #1
Format : PGS
Muxing mode : zlib
Codec ID : S_HDMV/PGS
Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs
Duration : 59mn 9s
Bit rate : 32.8 Kbps
Count of elements : 1400
Stream size : 13.9 MiB (0%)
Language : Japanese
Default : No
Forced : No
Text #2
Format : PGS
Muxing mode : zlib
Duration : 1h 2mn
Bit rate : 30.7 Kbps
Count of elements : 1228
Stream size : 13.8 MiB (0%)
Language : English
Default : No
Forced : No
Text #3
Format : PGS
Muxing mode : zlib
Duration : 1h 2mn
Bit rate : 20.9 Kbps
Count of elements : 1227
Stream size : 9.36 MiB (0%)
Language : Korean
Default : No
Forced : No
Text #4
Format : PGS
Muxing mode : zlib
Duration : 1h 2mn
Bit rate : 27.2 Kbps
Count of elements : 1221
Stream size : 12.2 MiB (0%)
Language : Chinese
Default : No
Forced : No
Menu
00:00:00.000 : en:00:00:00.000
00:00:59.059 : en:00:00:59.059
00:05:40.340 : en:00:05:40.340
00:12:56.609 : en:00:12:56.609
00:19:08.147 : en:00:19:08.147
00:25:55.554 : en:00:25:55.554
00:32:48.967 : en:00:32:48.967
00:39:17.355 : en:00:39:17.355
00:43:46.207 : en:00:43:46.207
00:48:31.909 : en:00:48:31.909
00:54:45.657 : en:00:54:45.657
00:59:54.591 : en:00:59:54.591
Bit depth : 10 bits
That is the problem. AVC 10 bit has next to no hardware support. Need to re-encode to a supported format. -
Ok! I'll inform what happened after re-encoding.
Thank you very much for the comment. -
Hey, just tried what you advised me and can confirm that it works!
Thanks a lot sneaker, I really appreciate it.
Help downloading a m3u8 file starting at a specific segment.
By qwerty480 in forum Video Streaming DownloadingReplies: 1Last Post: 2nd Sep 2016, 00:35 -
Specific file size for x265 encoding...
By alryan011 in forum Video ConversionReplies: 2Last Post: 26th May 2015, 17:09 -
Changing playing speed of MKV file
By djdj in forum EditingReplies: 7Last Post: 14th Apr 2015, 19:27 -
Getting MKV/MP4 to a specific file size
By pizzaboyUK in forum Newbie / General discussionsReplies: 3Last Post: 12th Sep 2014, 09:42 -
MKV file playing fine, but Blu-ray 'compatible' re-encode pixelates...
By Lathe in forum Authoring (Blu-ray)Replies: 5Last Post: 11th Dec 2013, 01:28
