Results 1 to 10 of 10
Ok, problem with avidemux is it not supported VP8 VP9 and other video conversion. But I believe KDENlive can export to webm easily. Lots of NLE software export to webm by default.
Edit - The problem is you have video in format that is not supported with webm container. If you have video in vp8 or vp 9 not in h263, h264 or h265 so there is no problem. You need to find software that can export video to VP 8 or 9 and audio to vorbis or opus. Then you can mux it to webm container in avidemux. But good luck with this video codec.
I wouldn't personaly touch anything to have something common with google with 10 foot long pole....
BernixLast edited by Bernix; 9th Aug 2018 at 15:31. Reason: Edit
You can try a lower number for crf and add a few other options as well. See this page for details. You could also try the VP9 encoder.
Trying this now:
Code:ffmpeg -i input.mp4 -c:v libvpx -qmin 0 -crf 5 -b:v 1M -c:a libvorbis output.webm
Better try this, a little slow but great quality (11 fps for a 720p video in a i7-7700HQ running at 2.8 Ghz):
Code:"ffmpeg.exe" -i input.mp4 -c:v libvpx-vp9 -pass 1 -passlogfile logfile -crf 24 -b:v 1000k -minrate 10k -maxrate 4000k -threads 8 -deadline good -cpu-used 4 -tile-columns 0 -frame-parallel 0 -qmax 32 -auto-alt-ref 1 -lag-in-frames 24 -g 240 -aq-mode 0 -an -f null NUL "ffmpeg.exe" -i input.mp4 -c:v libvpx-vp9 -pass 2 -passlogfile logfile -crf 24 -b:v 1000k -minrate 10k -maxrate 4000k -row-mt 1 -threads 8 -deadline good -cpu-used 1 -tile-columns 2 -tile-rows 0 -frame-parallel 0 -qmax 32 -auto-alt-ref 1 -lag-in-frames 24 -g 240 -aq-mode 0 -c:a libopus -b:a 96k -ac 2 -f webm "output.webm"
Convert WEBM to MP4 with audio
By cottage in forum Video ConversionReplies: 4Last Post: 7th Aug 2018, 16:03 -
ffmpeg convert from mkv to mp4 [matroska,webm @ 0x1d06640] Read error at
By blurry in forum Video ConversionReplies: 6Last Post: 15th Jan 2018, 06:36 -
Dealing with OPUS audio of MP4/WEBM/MKV
By ConverterCrazy in forum Newbie / General discussionsReplies: 3Last Post: 31st Dec 2017, 02:36 -
FREE converter WEBM to MPG, MP4, etc.?
By RowRowYourBoat in forum Video ConversionReplies: 5Last Post: 31st Jul 2017, 19:30 -
Webm to Mp4 encoding color problem
By Gigi1303 in forum Newbie / General discussionsReplies: 3Last Post: 24th May 2016, 08:34
