So here’s my situation:
I have a custom built Plex server that I also use for video conversion.
I personally don’t like plex’s subtitle support. So movies I aquire that have forced subtitles, I like to burn them in ahead of time.
By doing this I can save my servers CPU transcoding resources for other needs.
My question:
Is there conversion software that will only use my GPU and not the CPU?
I would also need this software to support HDR aka BT.2020
Thank you in advance!
If you want a GPU encoder, you want lower quality than the best available CPU encoders.
Apart from that, it's indeed possible that GPU vendors already provided video converters which use both the decoder and the encoder on the GPU (e.g. in case of Nvidia, PureVideo + NVEnc; or an intel converter using QuickSync for both GPU decoding and GPU encoding). But such converters will be very simple, if they exist at all. I really doubt they care about colorimetry.
I could imagine that Selur's Hybrid may support both separately, but the video would take a detour over RAM and CPU between both stages here. -
You can burn in subtitles with StaxRip which also supports GPU only encoding via Nvenc (which you can update manually to the latest version).
If you have a decent NVIDIA CARD you can have excellent, quick results, similar to fast settings say using x264 eg
BUT...CPU still beats GPU for quality.
AMD encoder still sucks.
Best H265 gpu accelerated video conversion software
By Wolluf in forum Newbie / General discussionsReplies: 32Last Post: 18th Jul 2024, 13:13 -
There is too much about GPU vs CPU encoding, but how about GPU filters?
By Bernix in forum Newbie / General discussionsReplies: 24Last Post: 16th Feb 2018, 16:17 -
Best GPU specs for 4k video playback?
By bitrape in forum Video Streaming DownloadingReplies: 2Last Post: 14th Nov 2016, 21:56 -
Video rendering; is CPU, GPU, or RAM more important?
By CursedLemon in forum Video ConversionReplies: 5Last Post: 9th Jul 2015, 15:00 -
encoding video why are cpu best vs gpu ?
By tola5 in forum Newbie / General discussionsReplies: 15Last Post: 11th Jun 2015, 15:39
