Hey guys,
I do lecture capture at a university and frequently after the lecture there is a brief q&a between the lecturer and the audience. I don't have the option to use a mic runner and the lectures occur in several different rooms so prepping the room for sound isn't an option either.
Currently, I mount a shotgun mic at the front of the room facing the audience and ramp it up in post.
Does anyone have any suggestions of a microphone array/placement to capture cleaner sound?
Thanks.
Is the shotgun stationary? If so, you will get better sound pointing it at each querent.
It is. Traditionally I am positioned at the back of the room so I can focus on the lecturer/presentation and I have the shotgun elevated and pointed down towards the audience.
Panasonic HC-V180 Recording Settings & Battery Advice
By TazDave in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 12th Jul 2017, 01:44 -
SubtitleWorkshop & MKV & LAV Filters & x263
By Moralez in forum Newbie / General discussionsReplies: 8Last Post: 28th Apr 2017, 19:26 -
Down & Dirty Recording TV
By cornemuse in forum Capturing and VCRReplies: 12Last Post: 19th Feb 2016, 13:03 -
Recording & editing Help
By rahulcrazy in forum EditingReplies: 3Last Post: 16th Mar 2015, 09:24 -
AVIDemux *^&%&$%^&$!@*(&^#*()&!#$)(*^*&^
By Kantanshi in forum Video ConversionReplies: 10Last Post: 29th Aug 2014, 23:40
