Hi,
I have a 1080x1080 photo and a 42 seconds MP3 audio file, I wanna merge these 2 and make a video file (MP4 H264 or H265) with 1x1 aspect ratio (for Instagram) with the constant picture playing my audio file.
What's the free software with UI doing this to get?
I don't know any software doing so with 1x1 AR, please introduce
Cheers.
Results 1 to 11 of 11
ffmpeg. This, in a batch file, will produce an mp4 file called output.mp4 from image.jpg and audio.mp3. The video will have the running time of the audio source.
Code:"C:\Program Files\ffmpeg\bin\ffmpeg.exe" -y -loop 1 -i "Image.jpg" -r 30.0 -i audio.mp3^ -c:a copy -c:v libx264 -preset ultrafast -tune stillimage -g 250^ -shortest output.mp4
Thanks, it made a video but Windows Media Player will play its audio only! Latest version of K-Lite Mega installed...
As well as PowerDVD... -
Thanks, it worked but not fully, now I see the picture, but the whole audio is 00:42 seconds, and from second 4 to 10 the video becomes gray!!!
Tried a second make and the same result!!! -
The command as I posted it worked perfectly. MediaInfo report:
Code:General Complete name : G:\Program Files\ffmpeg examples\Image and MP3 to Video\output.mp4 Format : MPEG-4 Format profile : Base Media Codec ID : isom (isom/iso2/avc1/mp41) File size : 14.0 MiB Duration : 3 min 34 s Overall bit rate : 547 kb/s Writing application : Lavf57.71.100 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : Baseline@L3.2 Format settings, CABAC : No Format settings, ReFrames : 1 frame Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 3 min 34 s Bit rate : 414 kb/s Width : 1 080 pixels Height : 1 080 pixels Display aspect ratio : 1.000 Frame rate mode : Constant Frame rate : 25.000 FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.014 Stream size : 10.6 MiB (76%) Writing library : x264 core 152 r2851 ba24899 Encoding settings : cabac=0 / ref=1 / deblock=0:-3:-3 / analyse=0:0 / me=dia / subme=0 / psy=1 / psy_rd=2.00:0.70 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=0 / threads=6 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=0 / weightp=0 / keyint=250 / keyint_min=25 / scenecut=0 / intra_refresh=0 / rc=crf / mbtree=0 / crf=23.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=0 Color range : Full Audio ID : 2 Format : MPEG Audio Format version : Version 1 Format profile : Layer 3 Mode : Joint stereo Codec ID : 6B Duration : 3 min 34 s Bit rate mode : Constant Bit rate : 128 kb/s Channel(s) : 2 channels Sampling rate : 44.1 kHz Compression mode : Lossy Stream size : 3.27 MiB (23%) Default : Yes Alternate group : 1
I think it can be done in Sony Vegas. Not sure about the free version though.
Last edited by divo2000; 8th Aug 2018 at 03:01. Reason: too much weird reaction somehow
As someone who made his living in the software industry, what I have to say to you cannot be printed in this forum.
Do you also boast publicly about all the merchandise you shoplift? No difference at all between stealing software and stealing things from a store.
When you look in the mirror, the face looking back to you is the face of a criminal.Last edited by johnmeyer; 7th Aug 2018 at 19:10.
In principle the statement of jagabo is fine and it works with VLC Player. To improve compatibility, here's my suggestion:
That works with Windows Media Player. I've just tested it.Code:ffmpeg -r 1/42 -i image.jpg -i audio.mp3 -pix_fmt yuv420p -c:v libx264 -preset fast -vf fps=fps=25 -c:a copy -y out.mp4
Please note: The number "42" at the beginning must be the exact duration of the audio in milliseconds. So, if the audio part has a length of e.g. 42505 ms, then replace the 42 by 42.505 please.Last edited by fornit; 7th Aug 2018 at 20:22. Reason: Set output framerate via vf instead of "-r" option
Maybe the simple command line worked for me because I was using a CBR mp3 file to test (with several different players). VBR mp3 might need more command line parameters.
Merge two audio tracks from MP4 video
By cawekun in forum Video ConversionReplies: 7Last Post: 27th Apr 2018, 07:54 -
Merge Video with audio
By curious_thomas in forum Newbie / General discussionsReplies: 3Last Post: 14th Oct 2016, 08:40 -
Question video/audio merge
By ultraman36 in forum EditingReplies: 4Last Post: 7th May 2016, 10:42 -
Cant merge mkv video and audio with mkvtoolnix?? any ideas?
By kjy in forum Newbie / General discussionsReplies: 5Last Post: 6th Jan 2016, 12:37 -
Merge MKV video and audio
By mlmiller707 in forum Newbie / General discussionsReplies: 1Last Post: 26th Nov 2015, 17:40
