Hi,
I want to use VSDC for removing some video footage (cutting) from files. E.g. MKV or MP4 etc. I have been trying to match the input but what happens is that VSDC resamples (apologies if it is the incorrect term) the video.
So, there are two issues:
A. It takes forever
B. File size of say an 800MB file becomes 2GB.
How can I simply use VSDC or any other open source editor to do that? Thanks.
A) Use faster encoder settings.
B) Set a lower bitrate.
<edit>
Oh, I see, you mean it's re-encoding. And you don't want to re-encode. I don't know if VSDC is capable of cutting without re-encoding. You can use AviDemux for simple cut editing -- but you can only cut on keyframes. VideoRedo support smart editing of MPEG 2 and h.264/AVC. That allows cutting on any frame and only cut GOPs will be re-encoded.
</edit>Last edited by jagabo; 3rd Aug 2018 at 23:53.
VSDC basic editing concept
By jotti in forum Newbie / General discussionsReplies: 5Last Post: 16th May 2019, 07:14 -
Resampling
By koberulz in forum AudioReplies: 4Last Post: 11th Nov 2017, 20:19 -
Editing VSDC sprites
By wilder in forum EditingReplies: 0Last Post: 16th Jun 2017, 14:38 -
VSDC Editing help
By Irfaankahan in forum EditingReplies: 2Last Post: 7th Apr 2016, 04:04 -
Recover footage rendered with Smart Resampling
By lonrot in forum EditingReplies: 22Last Post: 12th Jul 2014, 17:13
