Hi,
I am trying to use LAME with Tmpgenc by putting it in the external tools in enviromental settings. When I click start to begin the encode about a minute or two after i click a box comes up saying -
external encoder lame.exe was not properly run.-
does anybody know what i can do?
it might be something with the way i set up lame and the .exe file where it should be. I don't know.
breathe
It shouldn't have anything to do with how you set up lame...as long as you point TMPG toward where the .exe file is. it sounds like it is starting the audio encode--there should be a message at the bottom left saying, "creating temporal wave" or something like that--this means it has started the process, and TMPG is finding lame just fine. what type of audio is your source? if you haven't already done this, I would probably try to extract a wav with VirtualDub, and use that as the audio source...sometimes .mp3 audio gives problems with TMPG/lame.Originally Posted by h8hbreathe
if that doesn't work, maybe try besweet/gui
MP2 audio with LAME?
By RogerTango in forum AudioReplies: 7Last Post: 3rd Nov 2009, 23:28 -
Lame not showing up in VirtualDub
By DonGallego28 in forum AudioReplies: 3Last Post: 29th Oct 2008, 15:40 -
What would you do if you just saw a lame video?
By KnifeSoldier in forum Newbie / General discussionsReplies: 2Last Post: 25th Jun 2008, 06:23 -
Can't install Lame ACM
By suerpflysocal in forum Newbie / General discussionsReplies: 1Last Post: 7th Feb 2008, 09:16 -
To lame for HD?
By rhythminmind in forum Media Center PC / MediaCentersReplies: 5Last Post: 10th Oct 2007, 20:38
