Hello everyone, I'm looking for a camcorder to replaced my faulty Canon (Vixia) HF200.
As I reside in Singapore, the camcorder scene over here is pretty bleak and slow in introducing new models (the latest panasonic 4K model sold here is VX980 w/o viewfinder, a 2016 model)
Stumbled across the Panasonic HC-VX1 online which was newly released this year and kind of interested in it. Since Singapore does not have this model, I am deciding to purchase it online. Which means that I can either purchase from US (US model) or Australia (UK/Aust model), both of which are quite similarly and competitively priced.
However, this means that there is the slight variance of choices due to the country of origin, notably the 25p / 30p and 50p / 60p between the US and UK models.
[Attachment 46253 - Click to enlarge]
From the user manual picture attached, you can see that apart from the frame rate differences, the rest of the specs be it hardware or software is technically the same. The AC power charger issue can be solved by purchasing an adapter so it is fine.
My question is, does the frame rate matters in this case? Eg. Would a recording of 3840 x 2160 @ 30p (US model) be better than 3840x 2160 @ 25p (UK model) instead? I also know about the difference in video systems such as PAL and NTSC which ultimately affects the frame rate system.
(FYI, in Singapore, equipment and devices are designed and based on UK power settings @ 60hz).
Thank you for your help and advice in advance!
Results 1 to 1 of 1
iPad Mini 16GB Model MF432LL/A
By vhelp in forum Portable VideoReplies: 1Last Post: 10th May 2015, 20:43 -
Elgato Game Capture HD (not the 60 model)
By Cesar Schrega in forum Capturing and VCRReplies: 5Last Post: 23rd Dec 2014, 22:52 -
Curtis, Model: DVD7600
By holiday in forum Newbie / General discussionsReplies: 0Last Post: 11th Oct 2014, 13:56 -
Who made me, the band and model number are worn off
By reble in forum Portable VideoReplies: 1Last Post: 5th Mar 2014, 20:33 -
Hauppauge HD PVR 2: Is there a difference in Model Numbers?
By HyeVltg3 in forum Capturing and VCRReplies: 3Last Post: 19th Feb 2014, 15:04
