hello
anyone know what effect this is @-6:04, in the video
https://www.facebook.com/alternarivaholistica/videos/1817762378246446/
it's the white, very fast moving effect, like many book pages being passed in a very fast manner.
any similar effect in vegas, or something?
any help is appreciated!
Results 1 to 15 of 15
ok, thanks very much.
i won't be trying it out this time at least - customer wants a vid made fast and if this is not a fast thing to make, i guess i won't need to make it!
thanks -
Yes you can do it quite quickly and easily with a few keyframes, eased at the end
It's just a layer animation with motion blur.
In that example, you place 4 copies vertically opposed to one another, with a small gap in between each. Think of it as a long sheet. You animate it moving downwards. That small gap has transparency, so when the editor calculates the motion blur it blends the edges
If your editor doesn't have motion blur, you can get similar results with a vertical blur -
I can't get a copy of that because im not on Facebook. It looked complex at first glance. Send that thing in and we'll reverse engineer it for you for the future. Put it on YT.
You can use various downloaders to get facebook videos.
But the OP really should have cut that section and posted it here. Many people actually block Facebook because of ads and privacy issues
Here are the 1st 10 seconds, I'm assuming it's the correct video and the "effect" he's referring to is ~ 6-7 seconds in -
Thanks for that. It still looks pretty complex. Doncha Think? It's definitely professional.
Are we talking about the same thing ? He said "it's the white, very fast moving effect, like many book pages being passed in a very fast manner."
That's actually quite simple . It' s just simple layer animation (top to bottom in that example), motion blur . It's actually 2 keyframes in some programs (because the motion blur is "automatic") . If he is using a program that doesn't have motion blur it might be 4 or 6 keyframes to adjust the directional blur (vertical in that example) -
There's a whole lot of animation, within other animations, going on there.
He didn't ask about the other ones
The other one is a basic shape layer animation very likely done in after effects . The whole thing has an after effects vibe to it. (It can be done in other programs too, it's just easier to do in AE) -
I think I need a brain checkup. I saw something like a rain cloud passing over. No white passing effect.
OK.Next Time I'll insert the vid right here on the forum. Sry bout that. And yes its the white efect Between "alternativa holistica" and "quien somos". Thank you for the tips so far guys. I might give it a try with the help u guys gave me.
I see it now.
What would you call that? Nuclear Blast? With rotation?
I wanted to engage and reproduce this thing, but it's a bit underwhelming. I suppose the Glint tool in Vegas could do it.Last edited by budwzr; 4th Aug 2018 at 21:12.
this effect Adobe video editing programs can apply I?
Herhangi birşey nasıl yapılır öğrenin!
How does one achieve this/this effect?
By AmateurnFilmmaker in forum EditingReplies: 1Last Post: 15th Oct 2015, 17:57 -
How to get this effect?
By valcas in forum EditingReplies: 8Last Post: 8th Oct 2014, 18:01 -
By valcas in forum EditingReplies: 1Last Post: 7th Oct 2014, 21:00 -
may i know how do this effect?
By rama in forum EditingReplies: 40Last Post: 4th Oct 2014, 02:15 -
How to get the effect? :o
By RyanLOL in forum EditingReplies: 2Last Post: 30th Aug 2013, 18:37
