In the forum profile we can set the option to browse invisibly but on the front page and on forum pages there is a "Welcome USERID" showing at the top of the page. Is it possible to have the option to mask that field so over the shoulder snoopers can't see my ID while I'm logged onto the site? Thanks.
Try DVDFab Video Downloader and rip Netflix video! Or Try DVDFab and copy Blu-rays! or rip iTunes movies!
Results 1 to 10 of 10
There's not much to do but then I can't do much anyway. -
It should now be hidden if you are invisible.
Change to invisible mode under https://forum.videohelp.com/profile.php?do=editoptions -
Thanks that helps a lot. It works fine now on the forum index page and any forum page below that.
It is still showing the userid on the front page where it says "Welcome back USERID at the top right of the page.There's not much to do but then I can't do much anyway. -
Hmm. The front page is not as easy to fix. The vbulletin user database options flags are not that easy to understand...
....but I will try.
Code:// decipher 'options' bitfield $user['options'] = intval($user['options']); foreach ($vbulletin->bf_misc_useroptions AS $optionname => $optionval) { $user["$optionname"] = ($user['options'] & $optionval ? 1 : 0); //DEVDEBUG("$optionname = $user[$optionname]"); }
If the front page is too much trouble please don't sweat it. When I'm in a public area, I can easily jump into the forum index after logging in and navigate from there. What you've done is fantastic and does the job. It's just what I needed. I wish other site administrators were as accommodating as you have been over the years. Thanks again Baldrick.
I well recall Baldrick putting that info on the page because one user wanted to see it as if he could not post without seeing it.
Nut it's only a username and even if someone is looking over your shoulder it kinda means little. It's not as if you were in some pron site is it ? -
I know a lot of people with whom I enjoy conversation and opinions but it doesn't necessarily mean that I want to share my online personas with them.
If I told you what happened to a close friend of mine on a sports related forum exactly the way I describe I think you'd understand.There's not much to do but then I can't do much anyway. -
It should now be hidden on the front page also.
Code:SELECT username FROM user WHERE userid = 'userid' AND options & 512
Yes it's hidden on the front page too when invisible.
Many thanksThere's not much to do but then I can't do much anyway.
How to hide x264's metadata
By ben45 in forum Video ConversionReplies: 6Last Post: 26th Jul 2017, 20:39 -
PotPlayer: how to hide mouse cursor during video playback?
By potuser in forum Software PlayingReplies: 2Last Post: 29th Apr 2017, 12:22 -
Hide button in mpv like MPC-HC
By fighuass in forum Newbie / General discussionsReplies: 1Last Post: 4th Mar 2017, 15:34 -
Is there a universal way to hide srt subtitles in the txt file?
By jimdagys in forum SubtitleReplies: 5Last Post: 15th Dec 2014, 23:31 -
How to hide date/time on screen in Potplayer?
By flupke01 in forum Software PlayingReplies: 8Last Post: 25th Aug 2014, 02:51
