    Mar 2008
    I took a look in one of the PDF VCR service manuals on my PC
    and it either uses PG-641, some kind of molykote grease
    or something called AC-DM multitemp grease
    Perhaps you should consult the service manual for the device you're working on
  2. Nope - you should always use service manual to verify grease - there are different types of grease especially in precision mechanic like VCR's - different grease is used for plastic to plastic, different metal to metal and different for metal to plastic... sometimes "universal" grease can be used - lithium grease are most common but usually in general types of mechanics (cars but even cars use different types of grease). Those universal precision grease usually use aluminium not lithium but frequently they are non oil based so they chemistry can be different. If you can't use service manual with lubricants list then you should search for lubricants explicitly neutral to application area - like neutral to plastic etc
    Yeah, you don't want a lube that breaks down plastic over time, used on plastic areas.
    Refer to the service manual, always.
  4. This kind, I suppose:
    This is nøt å signåture.™
    Aug 2010
    San Francisco, California
    You want a lube that goes together like rama lama lama ka dinga da dinga dong.
