I'm trying to trim front and back of some videos. The back trims ok but the front is way off. I've tried a 7 second advance but that doesn't always work. It seems to me that there has to be something wrong if it's as much as 7 seconds off. And it's not just 1 but several. With some it works OK but with others it can anywhere from 5 to 8 or 9 seconds off. Any ideas?
Results 1 to 11 of 11
Anything you keep must start with a keyframe.
The data for most frames in highly compressed video do not contain everything required to reconstruct the frame. The data only contains differences from prior or future frames (for example "this frame is the same as the last one, just make these changes..."). Only keyframes contain all data needed to reconstruct a frame (like a JPEG file). If you remove a keyframe that's referenced by later frames you can no longer reconstruct those later frames. -
You have to use the two "Go to keyframe" buttons. Those will tell you where you can start a cut (for lossless trimming).
If you want to cut from any other point you have to ditch copy-mode and re-encode instead. -
What types of video? If it's xvid/divx (most .avi files) it's possible to cut on non key frames. It'll do smart rendering to re encode the bits that weren't cut on key frames.
With x264 (most .mp4 or .mkv, actually most video period) or HEVC you can't cut on non key frames without curruption of the output video. It won't do smart rendering qith those formats. -
With h.264/h.265 the keyframes may be 250 frames (10 sec) apart.I've tried a 7 second advance
Thanks for the replys...Hoser Rob, I am cutting MP4's & MKV's and I find that what you said is true. I'm now just cutting on the key frame which is close enough for what I'm doing.
SW for video trimming
By bluenite in forum Newbie / General discussionsReplies: 1Last Post: 24th Jun 2015, 08:09 -
Video stutters after trimming
By Freodon in forum EditingReplies: 120Last Post: 9th Jan 2015, 09:32 -
video trimming on android
By BobAchgill in forum EditingReplies: 6Last Post: 8th Apr 2014, 10:57 -
Accurate .avi trimming with Avidemux
By Freodon in forum EditingReplies: 2Last Post: 23rd Feb 2014, 10:08 -
Avidemux mpeg trimming--is MPEG PS muxer really lossless?
By bluescrubby in forum EditingReplies: 4Last Post: 8th Jan 2014, 07:18
