Hi. I posted this question at StackOverflow but didn't get an answer, so I figured I should have come to the experts here in the first place!
I used the sample code at https://codepen.io/ollieRogers/pen/lfeLc to show frames of a (background) video as the user scrolls the page. The webm video used there plays very smoothly, but my video at https://codepen.io/Scottybe/pen/PBEOzG stutters quite a bit, so I'm assuming the problem is with the video itself.
I've used ffprobe to see if I can tell the difference between the two videos with no luck. Both have similar frame sizes, bit rates, frame rates, and lengths.
Is there a recommended way to create html5 video files that will "scroll" smoothly, i.e, that will respond quickly to the window.requestAnimationFrame() call? (I got a hint it may have something to do with "fragmentation" but not sure what to do with it.) An ffmpeg command to encode correctly would be even better! Thanks!
Results 1 to 10 of 10
You need more keyframes - more keyframes = better seekability of your file (adverse effect is higher bitrate requirement) - perhaps you can favor more P frames and prevent to encode B frames - tested both video files for key frames with ffprobe and hey are dramatically different:
Code:@ffprobe -hide_banner -v 32 -stats -y -skip_frame nokey -i filename -select_streams v:0 -print_format compact -show_entries "frame=key_frame,pkt_pts_time" > "filename.txt"
for your video this is result:
and for reference:Code:frame|key_frame=1|pkt_pts_time=0.003000 frame|key_frame=1|pkt_pts_time=4.274000
in your case distance between keyframes is 4 seconds, where in reference there is approx .5 sec distance - decoder need o decode all frames between keyframes so you pushing CPU (and memory) load to max.Code:frame|key_frame=1|pkt_pts_time=0.033000 frame|key_frame=1|pkt_pts_time=0.434000 frame|key_frame=1|pkt_pts_time=0.834000 frame|key_frame=1|pkt_pts_time=1.235000 frame|key_frame=1|pkt_pts_time=1.635000 frame|key_frame=1|pkt_pts_time=2.035000 frame|key_frame=1|pkt_pts_time=2.436000 frame|key_frame=1|pkt_pts_time=2.836000 frame|key_frame=1|pkt_pts_time=3.237000 frame|key_frame=1|pkt_pts_time=3.637000 frame|key_frame=1|pkt_pts_time=4.037000 frame|key_frame=1|pkt_pts_time=4.438000 frame|key_frame=1|pkt_pts_time=4.838000 frame|key_frame=1|pkt_pts_time=5.239000 frame|key_frame=1|pkt_pts_time=5.639000 frame|key_frame=1|pkt_pts_time=6.039000 frame|key_frame=1|pkt_pts_time=6.440000 frame|key_frame=1|pkt_pts_time=6.840000 frame|key_frame=1|pkt_pts_time=7.241000 frame|key_frame=1|pkt_pts_time=7.641000 frame|key_frame=1|pkt_pts_time=8.041000 frame|key_frame=1|pkt_pts_time=8.442000 frame|key_frame=1|pkt_pts_time=8.842000 frame|key_frame=1|pkt_pts_time=9.243000 frame|key_frame=1|pkt_pts_time=9.643000 frame|key_frame=1|pkt_pts_time=10.043000 frame|key_frame=1|pkt_pts_time=10.444000 frame|key_frame=1|pkt_pts_time=10.844000 frame|key_frame=1|pkt_pts_time=11.245000 frame|key_frame=1|pkt_pts_time=11.645000 frame|key_frame=1|pkt_pts_time=12.045000 frame|key_frame=1|pkt_pts_time=12.446000 frame|key_frame=1|pkt_pts_time=12.846000 frame|key_frame=1|pkt_pts_time=13.247000 frame|key_frame=1|pkt_pts_time=13.647000 frame|key_frame=1|pkt_pts_time=14.047000 frame|key_frame=1|pkt_pts_time=14.448000 frame|key_frame=1|pkt_pts_time=14.848000 frame|key_frame=1|pkt_pts_time=15.249000 frame|key_frame=1|pkt_pts_time=15.649000 frame|key_frame=1|pkt_pts_time=16.049000 frame|key_frame=1|pkt_pts_time=16.450000 frame|key_frame=1|pkt_pts_time=16.850000 frame|key_frame=1|pkt_pts_time=17.251000 frame|key_frame=1|pkt_pts_time=17.651000 frame|key_frame=1|pkt_pts_time=18.051000 frame|key_frame=1|pkt_pts_time=18.452000 frame|key_frame=1|pkt_pts_time=18.852000 frame|key_frame=1|pkt_pts_time=19.253000 frame|key_frame=1|pkt_pts_time=19.653000 frame|key_frame=1|pkt_pts_time=20.053000 frame|key_frame=1|pkt_pts_time=20.454000 frame|key_frame=1|pkt_pts_time=20.854000 frame|key_frame=1|pkt_pts_time=21.255000 frame|key_frame=1|pkt_pts_time=21.655000 frame|key_frame=1|pkt_pts_time=22.055000 frame|key_frame=1|pkt_pts_time=22.456000 frame|key_frame=1|pkt_pts_time=22.856000 frame|key_frame=1|pkt_pts_time=23.257000 frame|key_frame=1|pkt_pts_time=23.657000 frame|key_frame=1|pkt_pts_time=24.057000 frame|key_frame=1|pkt_pts_time=24.458000 frame|key_frame=1|pkt_pts_time=24.858000 frame|key_frame=1|pkt_pts_time=25.259000 frame|key_frame=1|pkt_pts_time=25.659000 frame|key_frame=1|pkt_pts_time=26.059000 frame|key_frame=1|pkt_pts_time=26.460000 frame|key_frame=1|pkt_pts_time=26.860000 frame|key_frame=1|pkt_pts_time=27.261000 frame|key_frame=1|pkt_pts_time=27.661000 frame|key_frame=1|pkt_pts_time=28.061000 frame|key_frame=1|pkt_pts_time=28.462000 frame|key_frame=1|pkt_pts_time=28.862000 frame|key_frame=1|pkt_pts_time=29.263000 frame|key_frame=1|pkt_pts_time=29.663000 frame|key_frame=1|pkt_pts_time=30.063000 frame|key_frame=1|pkt_pts_time=30.464000 frame|key_frame=1|pkt_pts_time=30.864000 frame|key_frame=1|pkt_pts_time=31.098000 frame|key_frame=1|pkt_pts_time=31.498000 frame|key_frame=1|pkt_pts_time=31.899000 frame|key_frame=1|pkt_pts_time=32.299000 frame|key_frame=1|pkt_pts_time=32.699000 frame|key_frame=1|pkt_pts_time=33.100000 frame|key_frame=1|pkt_pts_time=33.500000 frame|key_frame=1|pkt_pts_time=33.901000
So you need to control so called GOP size (or better introduce more keyframes within longer GOP) and force video codec to produce video with plenty of Random Access Points.
More I and P frames, reduce or no B frames should improve seekability. Have no experience with VP8 (it is clearly seen why H.264 is more superior).
Perfectly smooth random access require only Intra frames (all frames are keyframes) but bitrate requirements are very high for such video - so you need to find optimal ratio between I and P frames (perhaps B too) - for older codecs it was around .5seconds (that's why for DVD GOP is 12 - 15 max 18 frames long - depend on framerate).Last edited by pandy; 30th Jul 2018 at 10:18. Reason: added some details
made simple script to encode webm with vorbis and vp8 - perhaps it will be helpful
Code:@rem set audio quality @set aq=3 @rem set video quality @set vq=8 @rem set GOP size @set GOP=15 @rem set number of B frames @set B=2 @set /A k_min=(%GOP%/4)+1 @set /A qpmin=(%vq%/4)+3 @set filename=%~1 @rem audio signal processing @set aproc="pan=stereo|FL < FL+1.414FC+0.5BL+0.5SL+0.25LFE|FR < FR+1.414FC+0.5BR+0.5SR+0.25LFE,firequalizer=gain='if(gte(f,30),0,-INF)+if(lte(f,14000),0,-INF)',dynaudnorm=p=1/sqrt(2),firequalizer=gain='if(gte(f,30),0,-INF)+if(lte(f,14000),0,-INF)',aresample=resampler=soxr:osr=44100:cutoff=0.990:precision=20:dither_method=0" @rem video signal processing @set vproc="pp=ac,scale=480:-4:sws_flags=spline+accurate_rnd+full_chroma_int+full_chroma_inp:interl=-1:out_range=auto:out_color_matrix=bt601,format=pix_fmts=yuv420p" @ffmpeg -hide_banner -loglevel 32 -stats -color_range 2 -y -i "%filename%" -c:v libvpx -tune 0 -deadline best -quality best -rc_lookahead %GOP% -q:v %vq% -crf %vq% -qmin %qpmin% -bf %B% -keyint_min %k_min% -g %GOP% -vf %vproc% -color_range 2 -pix_fmt yuv420p -af %aproc% -c:a libvorbis -q:a %aq% -f webm -dash 0 "%~n1.webm"
Thanks Pansy! I’ll try this out when I get home (as well as create the other html5 video formats) and let you know how it goes.
Pansy, I spent a little time converting your script from Windows to Mac!
output:Code:newname="new_$1" # set audio quality aq=3 # set video quality vq=8 # set GOP size GOP=15 # set number of B frames B=2 let k_min=(GOP/4)+1 let qpmin=(vq/4)+3 #audio signal processing aproc="pan=stereo|FL < FL+1.414FC+0.5BL+0.5SL+0.25LFE|FR < FR+1.414FC+0.5BR+0.5SR+0.25LFE,firequalizer=gain=\"expr:if(gte(f,30),0,-INF)+if(lte(f,14000),0,-INF)\",dynaudnorm=p=\"expr:1/sqrt(2)\",firequalizer=gain=\"expr:if(gte(f,30),0,-INF)+if(lte(f,14000),0,-INF)\",aresample=resampler=soxr:osr=44100:cutoff=0.990:precision=20:dither_method=0" # video signal processing vproc="pp=ac,scale=480:-4:sws_flags=spline+accurate_rnd+full_chroma_int+full_chroma_inp:interl=-1:out_range=auto:out_color_matrix=bt601,format=pix_fmts=yuv420p" command="ffmpeg -hide_banner -loglevel 32 -stats -color_range 2 -y -i $1 -c:v libvpx -tune 0 -deadline best -quality best -rc_lookahead $GOP -q:v $vq -crf $vq -qmin $qpmin -bf $B -keyint_min $k_min -g $GOP -vf $vproc -color_range 2 -pix_fmt yuv420p -af $aproc -c:a libvorbis -q:a $aq -f webm -dash 0 $newname" echo $command
Unfortunately, when I execute the ffmpeg command, I get:Code:ffmpeg -hide_banner -loglevel 32 -stats -color_range 2 -y -i test.webm -c:v libvpx -tune 0 -deadline best -quality best -rc_lookahead 15 -q:v 8 -crf 8 -qmin 5 -bf 2 -keyint_min 4 -g 15 -vf pp=ac,scale=480:-4:sws_flags=spline+accurate_rnd+full_chroma_int+full_chroma_inp:interl=-1:out_range=auto:out_color_matrix=bt601,format=pix_fmts=yuv420p -color_range 2 -pix_fmt yuv420p -af pan=stereo|FL < FL+1.414FC+0.5BL+0.5SL+0.25LFE|FR < FR+1.414FC+0.5BR+0.5SR+0.25LFE,firequalizer=gain="expr:if(gte(f,30),0,-INF)+if(lte(f,14000),0,-INF)",dynaudnorm=p="expr:1/sqrt(2)",firequalizer=gain="expr:if(gte(f,30),0,-INF)+if(lte(f,14000),0,-INF)",aresample=resampler=soxr:osr=44100:cutoff=0.990:precision=20:dither_method=0 -c:a libvorbis -q:a 3 -f webm -dash 0 new_test.webm
I'm stuck. Any idea where I went wrong? Thanks!Code:-bash: FL+1.414FC+0.5BL+0.5SL+0.25LFE: No such file or directory -bash: FR+1.414FC+0.5BR+0.5SR+0.25LFE,firequalizer=gain=expr:if(gte(f,30),0,-INF)+if(lte(f,14000),0,-INF),dynaudnorm=p=expr:1/sqrt(2),firequalizer=gain=expr:if(gte(f,30),0,-INF)+if(lte(f,14000),0,-INF),aresample=resampler=soxr:osr=44100:cutoff=0.990:precision=20:dither_method=0: No such file or directory Trailing options were found on the commandline. Input #0, matroska,webm, from 'test.webm': Metadata: encoder : Lavf52.62.0 Duration: 00:00:34.18, start: 0.033000, bitrate: 473 kb/s Stream #0:0(eng): Video: vp8, yuv420p(pc, progressive), 640x360, SAR 1:1 DAR 16:9, 29.97 fps, 29.97 tbr, 1k tbn, 1k tbc (default) Stream #0:1(eng): Audio: vorbis, 44100 Hz, stereo, fltp (default) At least one output file must be specified -
You're probably missing an escape or parentheses. But I don't see why you need all those options. Just way overcomplicating things. I don't think you have 5.1 audio right ? I'd just cut all that crap out to the most simplest and go from there if you still want to add options or customize things
If you just want to set the max keyframe interval it would be -g in ffmpeg . e.g. -g 15 would be a max keyframe interval of 15
I downloaded your video and tested it locally, and indeed there was high latency scrolling (tested locally, to rule out bandwidth issues)Code:ffmpeg -i input.ext -c:v libvpx -b:v 1.5M -g 15 -c:a libvorbis -b:a 128k output.webm
So I took your video and re-encoded it using those settings (really only the -g 15 is the most important) , plugged it back into the HTML5/JS code and it scrolled smoothly (the quality of the video was low, but it was low to begin with)
If you're still experiencing stutter or high latency scrolling, then i would do a local host test first (to rule out CDN bandwidth issues) . If there it's still too slow for you (it was about the same as the original demo for me, maybe even smoother) , you can look at other things like reducing the keyframe interval even more, or capping bitrate (VBV). Report back if you still need help with optimizing encoding settings, but I think that should be good enough -
More questions Pandy!
Here's my working shell script for others who may want to do the same thing:
I'm very much a beginner with ffmpeg. What settings would keep the output at the same quality as the original video?Code:newname="new_$1" # set audio quality aq=3 # set video quality vq=8 # set GOP size GOP=15 # set number of B frames B=2 let k_min=(GOP/4)+1 let qpmin=(vq/4)+3 #audio signal processing aproc="pan=stereo|FL < FL+1.414FC+0.5BL+0.5SL+0.25LFE|FR < FR+1.414FC+0.5BR+0.5SR+0.25LFE,firequalizer=gain='if(gte(f,30),0,-INF)+if(lte(f,14000),0,-INF)',dynaudnorm=p=1/sqrt(2),firequalizer=gain='if(gte(f,30),0,-INF)+if(lte(f,14000),$ # video signal processing vproc="pp=ac,scale=480:-4:sws_flags=spline+accurate_rnd+full_chroma_int+full_chroma_inp:interl=-1:out_range=auto:out_color_matrix=bt601,format=pix_fmts=yuv420p" command="ffmpeg -hide_banner -loglevel 32 -stats -color_range 2 -y -i \"$1\" -c:v libvpx -tune 0 -deadline best -quality best -rc_lookahead $GOP -q:v $vq -crf $vq -qmin $qpmin -bf $B -keyint_min $k_min -g $GOP -vf \"$vproc\" -color_ra$ eval $command
Also, how can I do the same thing for mp4 version?
You can adjust video quality by CRF factor - this is recommended way - generally for modern codecs short GOP's may deliver suboptimal quality so ability to seek video may be contradictory to "best quality at particular bitrate". VP8 is very limited (i was not aware this but seem VP8 doesn't support B frames
Keeping "same quality" is usually impossible as loosing quality is unavoidable when lossy codec is used - you can only try to keep quality sufficiently close to original but at some point you may end in bitrates higher than source - depends on you...
Webm, MP4 are video containers - in ffmpeg video containers are controlled by option '-f' so if you decide to change container you can use simply '-f mp4' (also ffmpeg is sufficiently smart to automatically select desired container based on your output file extension - so using 'filename.mp4' there is high chance that ffmpeg will use mp4 container not for example wav or avi) - usually container may have additional features controlled by flags or commands - for example YT recommends to use flag faststart (Run a second pass to put the index (moov atom) at the beginning of the file) so i use:Not sure what codec will be used by you with mp4 container - don't know if VP8 is supported by mp4 anyway unless VP8 is absolute must (web browser & HTML5 video object capabilities) then i would recommend something modern like H.264 or VP9 (beware that VP8, VP9 encoders are usually way slower than H.264).Code:-f mp4 -movflags faststart
And yes, my scripts share similar structure so they are "full of crap" (by principle - they work for me so they should work for you too).
And yes, i was aware of 'pansy' meaning but i assumed this is not intentional typo thus don't care.
ffmpeg convert from mkv to mp4 [matroska,webm @ 0x1d06640] Read error at
By blurry in forum Video ConversionReplies: 6Last Post: 15th Jan 2018, 05:36 -
Ffmpeg –Mencoder – Avconv = Convert video.avi for Web (Html5)
By morsejr in forum Video ConversionReplies: 2Last Post: 6th Nov 2017, 09:38 -
Using FFMPEG how do I convert an entire folder of webm files to wav or mp3?
By alphainventions in forum Video ConversionReplies: 1Last Post: 7th Aug 2016, 19:56 -
webm vp9 hardware decoding in html5 players
By codemaster in forum Software PlayingReplies: 3Last Post: 30th Jun 2016, 21:35 -
WEBM creation with ffmpeg: broken video in MPC-HC and Explorer
By pokepika in forum Video ConversionReplies: 8Last Post: 16th Dec 2013, 19:42
