Closed Thread
    Jul 2018
    Europe
    So, i want to make my first BRRip. I'm using VirtualDubMOD as the encoder. With audio i have no problem at all. But it gets all stuck on the video part (Bitrate & Filesize). I set my bitrate to 2900 so the file size is around 1.7GB. And i use 2-pass encoding. When encoding is done i always get filesize around 700-900MB, and bitrate around 1500kbps lower then it should be. So i really don't get it. What's causing the issue?
    Info about video i'm trying to endcode:
    Format : Matroska
    Format version : Version 4 / Version 2
    File size : 3.28 GiB
    Duration : 1 h 8 min
    Overall bit rate : 6 888 kb/s
    Encoded date : UTC 2017-11-01 22:55:31
    Writing application : mkvmerge v8.3.0 ('Over the Horizon') 64bit
    Writing library : libebml v1.3.1 + libmatroska v1.4.2
    Video
    Format : AVC
    Format profile : High@L4.1
    Format settings : CABAC / 5 Ref Frames
    Format settings, CABAC : Yes
    Format settings, RefFrames : 5 frames
    Codec ID : V_MPEG4/ISO/AVC
    Bit rate : 5 378 kb/s
    Width : 1 280 pixels
    Height : 720 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 23.976 FPS
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.243
    Stream size : 2.56 GiB (78%)
    Writing library : x264 core 152 r2851 ba24899
    Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=22 / lookahead_threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=5378 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
    Language : English
    Default : Yes
    Forced : No
    Audio
    Format : DTS
    Format/Info : Digital Theater Systems
    Codec ID : A_DTS
    Bit rate mode : Constant
    Bit rate : 1 509 kb/s
    Channel(s) : 6 channels
    Channel positions : Front: L C R, Side: L R, LFE
    Sampling rate : 48.0 kHz
    Frame rate : 93.750 FPS (512 SPF)
    Bit depth : 24 bits
    Compression mode : Lossy
    Stream size : 735 MiB (22%)
    Language : English
    Default : Yes
    Forced : No
    Menu
    00:00:00.000 : en:00:00:00.000
    00:01:47.607 : en:00:01:47.607
    00:14:14.896 : en:00:14:14.896
    00:22:41.235 : en:00:22:41.235
    00:33:14.451 : en:00:33:14.451
    00:43:01.370 : en:00:43:01.370
    00:54:44.781 : en:00:54:44.781
    01:06:51.257 : en:01:06:51.257
    This is what i get:
    Format : AVI
    File size : 828 MiB
    Overall bit rate : 1 700 kb/s
    Writing application : VirtualDubMod 1.5.10.3 | www.virtualdub-fr.org || (build 2550/release)
    Writing library : VirtualDubMod build 2550/release
    Video
    Format : MPEG-4 Visual
    Format profile : Advanced Simple@L5
    Format settings : BVOP1
    Format settings, BVOP : 1
    Format settings, QPel : No
    Format settings, GMC : No warppoints
    Format settings, Matrix : Default (H.263)
    Codec ID : XVID
    Codec ID/Hint : XviD
    Bit rate : 1 243 kb/s
    Width : 720 pixels
    Height : 400 pixels
    Frame rate : 23.976 (24000/1001) FPS
    Color space : YUV
    Bit depth : 8 bits
    Bits/(Pixel*Frame) : 0.180
    Stream size : 605 MiB (73%)
    Writing library : XviD 67
    Audio
    Format : AC-3
    Format/Info : Audio Coding 3
    Codec ID : 2000
    Bit rate : 448 kb/s
    Frame rate : 31.250 FPS (1536 SPF)
    Bit depth : 16 bits
    Stream size : 218 MiB (26%)
    Alignment : Split accross interleaves
    Interleave, duration : 42 ms (1.00 video frame)
    Interleave, preload duration : 500 ms
    Service kind : Complete Main
  2. Member Cornucopia's Avatar
    Hard to say since you didn't give any particulars about your settings, other than "2900". Maybe you are using that number for Max instead of Average. Maybe you need to specify it during both passes (not sure as I never use vdubmod anymore, since mid 2000s).
    More info needed...
  3. Did you manually run both the first and second passes? VirtualDub doesn't automatically run both passes.
    Is this a very clean (little noise) animation? It may simply be that the encoder can't give as high a bitrate as you asked for with the specified settings. Check the min quantizer settings. Make them lower.
    Jul 2018
    Europe
    Well, i was following this guide --> http://www.sb-innovation.de/f209/how-create-xvid-brrip-720p-mkv-19364/. I want to encode Westworld.S01.E01.Bluray.x264 to Xvid.
    Jul 2007
    Buy the actual Blu-Ray instead of illegal downloads.
  6. I'm a Super Moderator johns0's Avatar
    canada
    Aircraft-please do not ask for help on illegally downloaded blu-ray rips,this is against forum rules,this thread is closed.
