Is there a standard way to detect whether an HDMI/DVI video signal is progressive or interlaced?
Thanks in advance.
Results 1 to 10 of 10
However, I suspect this is done via HDMI handshake signals. What this means is that unless you are building hardware that you won't be able to get this information. Put another way, the only way the video from that HDMI source can get on your computer or phone is if it is captured. That capture process may, or may not, include all the information that is in the original signal. This is nothing new because, of course, analog NTSC video had all sorts of information embedded in line 21 and elsewhere and almost all of this was routinely stripped by the capture software.
Someone with more insight into HDMI will probably have a better answer. -
Yes, if you try to detect interlaced/progressive by actually looking at the video frames/fields, that is what you have to do. However, since he had the word "HDMI" in there, I assumed he was talking about some of the handshake data that is part of the spec. I am 100% certain that this is how my set knows to display 1080i or 720p.
As for detecting it just by analyzing the video itself, I know this was often discussed a decade ago in the doom9.org forum. What you need is a function that can detect the "teeth" that are visually so obvious when you freeze-frame an interlaced video that has lots of horizontal motion. I can't remember if anyone came up with a good function, but my instinct tells me that this should be possible, especially if you write the function to look at a large number of frames, in order to find frames with lots of movement.Last edited by johnmeyer; 26th Jul 2018 at 17:09. Reason: clarification
Yes, i know, you can observe DDC communication - easy to do by one of those cheap logic analysers like https://www.saleae.com/ or cheaper clone https://hallard.me/cheap-and-usefull-logic-analyzer/ , necessary HDMI DDC (EDID) decoding is already done but at best only selected video mode can be determined not the content...
Found my own answer here:
Video Demystified: A Handbook for the Digital Engineer
on page 151 it indicates
1) an odd field (field1) is indicated by coincident hsync/vsync leading edges
2) an even field (field2) is indicated by a vsync leading edge half way through the video line
here is a link to it:
https://books.google.com/books?id=6dgWB3-rChYC&pg=PA151&lpg=PA151&dq=vsync+hsync+in+in...0video&f=falseLast edited by tl_rtclancy; 31st Jul 2018 at 15:22.
I know that Oppo and some other high-end DVD players (Denon) can do it, in order to prevent such things as interlaced content that was encoded as progressive (it happens) from being passed through unchanged, They can also perform on-the-fly IVTCs, where almost all other DVD players (the flag-reading ones) will simply deinterlace that material.
I know nothing about Blu-Ray players but assume some can prevent mis-encoded material from being passed through incorrectly.
Also, AutoGK pioneered in detecting if DVD material needed to be deinterlaced or IVTC'd or neither. It then went ahead and did what had to be done without user intervention. -
interlaced or progressive: where are the flags?
By marcorocchini in forum Newbie / General discussionsReplies: 0Last Post: 30th Mar 2016, 11:23 -
Tablet HDMI out to VGA/DVI of old 17" monitor
By tector in forum Newbie / General discussionsReplies: 2Last Post: 6th Nov 2015, 08:11 -
Is it possible to detect that any HDMI/DVI video grabber is attached?
By eiger5678 in forum Capturing and VCRReplies: 5Last Post: 27th Sep 2015, 16:02 -
HDMI changes DVI resolution
By Lamanator in forum DVB / IPTVReplies: 7Last Post: 22nd Mar 2015, 11:26 -
DVI or HDMI "bypassing" Hot Plug Detect
By JSUMM60 in forum Newbie / General discussionsReplies: 3Last Post: 19th Mar 2014, 17:22
