I have this composite/s-video card but it seems a bit flaky.
I use VirtualDub to capture as I can then capture in Huffy and the filters settings show (doesn't in its native capture app Capture Studio, go figure) to set brightness etc, but it doesn't "stick". I have to change the settings during capture which is a bit annoying!
So does anyone use a capturing app that works better for this card?
First, I have no experience with this card. You may need to set up a capture profile each time you capture regardless of software because neither the card nor the software remembers previous settings.
Although it has been a while since I used any of them, I do know of some other capture software that works with many other cards capable of uncompressed capture. AmaRecTV and DScaler are the two that seem the most popular with VideoHelp members. There is also GraphStudio if you know how to build filter graphs.Ignore list: hello_hello, tried, TechLord, Snoopy329 -
Cool thanks, will try those apps you mentioned.
As for "set up a capture profile", how do I do that? Its weird as soon as I capture. So after a capture, the levels settings is set to what I put them at. Just dont get applied as soon as I hit Capture. -
By capture profile, I meant the list of device settings that you used in Virtualdub for a particular video source. You should keep notes about the settings you used for the source so they can be applied again in the future, if necessary. I'm guessing that you do that.
I don't know why you can't set up your device until after you begin a capture, and why the settings are not retained. It may well be the device.
I'm sorry I can't be of much help anymore. I'm unable to run any experiments with a capture device I own to see if it behaves differently with different software. Several months ago, I needed to re-install Windows and I made the decision to not to install drivers for my rather old capture device and the software I used with it for uncompressed capture because I don't need to capture anything anymore.Ignore list: hello_hello, tried, TechLord, Snoopy329 -
This is another reason I like my Osprey 210e card. It has dedicated GUIs for the video and audio drivers. The apps stay open and the controls are live throughout capture.
How to use ffmpeg to capture from Avermedia video card?
By Chemist116 in forum Capturing and VCRReplies: 2Last Post: 10th Nov 2017, 13:23 -
Issues with AVerMedia Capture Card and AmaRec
By ArianK in forum Newbie / General discussionsReplies: 1Last Post: 10th Aug 2017, 15:07 -
Avermedia M791 PCIe
By Boozer in forum Capturing and VCRReplies: 0Last Post: 14th Feb 2015, 01:43 -
AverMedia LGP Capture Card Problem
By OutaTime27 in forum Capturing and VCRReplies: 2Last Post: 24th Aug 2014, 10:31 -
AverMedia H727 HD Capture PCIe problems!
By daryljones92 in forum Capturing and VCRReplies: 17Last Post: 1st Feb 2014, 17:41
