I remember using the VirtualDub, VirtualDubMod and VirtualDub AIO once upon to resize videos to upload some video clips to Youtube. I use to cut some clips, I resize the videos and save them in AVI using the Xvid codec but what I heard on this very forum is that MP4 is much better quality. What I want to know is that should I use that method to continue upload videos to Youtube? Or should I look into some other program that will allow me to cut and resize clips? I don't really mind saving them in AVI but I do want good quality for my clips.
Use tool you like, always deliver highest quality - if you have fast upload capabilities don't bother reducing your upload file - select preset very fast or similar with sufficiently high bitrate or better lower cfr (as such higher quality). Youtube will re-encode your video anyway thus spending hours on squeezing your upload with high quality is waste of time. You can use some trick as YT will allocate more bitrate to 4K source then you may wish to upscale your source before uploading to 4K resolution.
AVI and MP4 are containers. Containers have no bearing on the quality of what's in them. The codecs and settings used determine the quality.
resizing videos while accounting for cropping and aspect ratio
By vhelp in forum Video ConversionReplies: 40Last Post: 11th Dec 2016, 00:10 -
Virtualdub, x264vfw, resizing and Youtube
By Guernsey in forum Newbie / General discussionsReplies: 8Last Post: 4th Sep 2016, 23:31 -
(VirtualDub) Not correctly resizing a video
By AmazingIvola in forum EditingReplies: 3Last Post: 12th Mar 2016, 08:26 -
Resizing videos to the same res without losing quality.
By quetzalin in forum Newbie / General discussionsReplies: 20Last Post: 5th Sep 2015, 07:59 -
Question about resizing several videos at once
By Basher06 in forum Newbie / General discussionsReplies: 22Last Post: 26th Mar 2015, 04:56
