is there any software regardless of operating system - free or paid for that allows keyframing for audio effects that DJ s would use for mixing ? reverb flanger etc that then allows me to keyframe those effects ? not just the normal audio effects. like fade in and fade out. not just loudnes etc.
only for audio not video keyframing.
thanks
Results 1 to 21 of 21
Sorry but the whole point of a DJ is to mix effects on-the-fly and not to pre-mix which is what you propose.
And key-frames is for the video realm. Audio streams know zilch about frames.
Already pointy out that there does exist audio editors yet, again, the true DJ will do these in real time and not rely on pre-prepared items. -
Exactly! Should be through Ableton Live and/or Push console.
[Attachment 46172 - Click to enlarge]Last edited by budwzr; 24th Jul 2018 at 13:29.
ProTools CAN easily do live/real-time playback FX adjustments, though, btw. Midi control is common.
For DJ stuff, Abelton does make more sense.
Scott -
Pro Tools does not run on Linux. For what you want to do, Ableton or Native Instruments Traktor would seem to be better. https://www.native-instruments.com/en/products/traktor/dj-software/
Canon C100 mk2 - Dell XPS8700 i7 - Win 10 - 24gb RAM - GTX 1060/6GB - DaVinci Resolve Studio 18.6.3 - Blackmagic Speed Editor - Presonus Faderport 1 - 3 calibrated screens -
no worries
it seems Qtractor allows you do that but its a bitch to learn the so called automation that allows it.
ia am struggling to figure out how to apply more than one plug in and keyframe it differently for each one and the different setting within each plug in.
but at least something exist that allow you to that.Last edited by oduodui; 26th Jul 2018 at 04:56.
What I still don't understand is the original requisites: "key-framing" and "on-the-fly" are kind of mutually exclusive, don't you think?
If you are in a live situation and need to change a control in realtime, how would you have already put down a marker to make some point a keyframe if it didn't occur yet. OTOH, if you already had the soundfile and make keyframes for your changes, there is no "on-the-fly" going on there.
Scott -
No you can't ... there's no native Linux version and it's rated Garbage in the Wine app database. But WIne is actually a ridiculous hack and usually fails, and other 'emulators' are all Wine based. There's no Ableton Linux version either.
The only Linux DJ software I've ever heard anything good about is mixxx but I've never used it.
The thread title says "software regardless of operating system" and for pro audio tools Linux is severely lacking. Use Windows for that stuff. And I'm saying this as someone who deleted all his Windows partitions. Go to linuxmusicians.org to see the state of things. -
yes they are i suppose. i want to take a piece of music and just be able to edit and change it with different effects on a timeline and be able to adjust those effects so that the effects works with one on a trial and error basis since i have ni musical ability and just create something to my liking. its not going to be for anyone else. definitely not live for an audience . just a past time if you will,.
Ok, sounds like you want keyframing capability with the FX parameters able to be live controlled, but that those control points have automation record/latch capability. That way you play the file multiple times, do multiple automation record passes (takes), change a few of the sections when necessary with latch passes, then go into the recorded automation points and tweak to your desired intent. All without knowing music beyond your gut groove.
Not sure of the other apps, but ProTools can do that in spades. Win or Mac, but not Linux, though you originally mentioned that was no issue.
Scott -
It sounds like OP wants to build a super custom MusikMaker universal array played out on a Push (or other) Console. Interesting. That's what Ableton DJ's do is to actually "Perform" the musik live.
Check out Novation Launch Pad. And Akai mini keyboard. Those two, plus Ableton Live software should do all you need. That's entry level, except for Ableton, which is pro, but should do what you want for cheap entry level price. Ableton has tons of automation. Get the Standard Version.
Myself, I'm a "loops" musician. I think that's what you want.Last edited by budwzr; 31st Jul 2018 at 18:35.
Install Kali Linux on Chromebook as the Only Operating System
By Teutatis in forum LinuxReplies: 3Last Post: 28th Apr 2016, 21:34 -
Paid - but no software
By Hocput in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 29th Dec 2014, 07:44 -
Partition Software and Operating System
By Teac23 in forum ComputerReplies: 27Last Post: 13th Dec 2014, 13:07 -
Installing new Operating system in Acer Netbook
By dfisher052 in forum ComputerReplies: 45Last Post: 31st Oct 2014, 09:15 -
Are there any powerful, error free paid software to edit Mp4 & avi files?
By seymoria in forum EditingReplies: 1Last Post: 8th Feb 2014, 14:34
