I have a 3 hour .ts file with little skips in the audio every minute of the broadcast. Is there a way to remove the skips using ffmpeg? And without causing an audio sync issue.
I don't know if this matters, but the skipping comes from the original broadcast. It is not the fault of the recording or recording device.
If your skipping parts is just silence, don't need to worry too much about that, since you can't "fix" it.
In your case the audio editor probably wont be able to help you, but in general,
it can change volume levels, do noise reduction, treble/bass equalization, slow down/speed up, pitch change, etc,etc. and
a whole lot more if/when you need it. -
Hm,
does this mean that your audio has gaps or is there simply silence?
The gap-thing can become annoying if you e.g. try to create a VP9/Opus dash stream as it will cause Shaka Player to fail.
I've had that problem and the solution has been to fill the gaps with silence. That can be done with ffmpeg and the following audio filter:
-af aresample=async=1:first_pts=0Last edited by fornit; 23rd Jul 2018 at 18:42.
The ability to fix this depends a LOT on not only how long the gap is, but what the surrounding audio is like.
I use a professional tool called iZotope (it is very expensive, but you can download a free trial). It has a "replace" function in its Spectral Repair module that can sometimes do a miraculous job of filling in a gap. The shorter the gap, the more invisible the fix.
Another way to fix is to copy/paste audio from other sections of the audio. I first learned to do this back in the early days of Napster when many of the uploaded files were screwed up, either because of incompetence, or by music industry people who tried to inundate Napster with broken audio. Here is a short clip of a song I'd tried to find for decades which showed up on Napster, but with some of the audio missing. It is a cover of what used to be an obscure Beatles song called "Bulldog." This cover was done back in 1971 by the original all-women rock group called Fanny. In this case the "gap" was a needle skip on the record someone got the music from. I was able to insert the missing music from a later chorus where the music was repeated almost exactly. The attached 23 second file starts with the broken version and then after one second of silence, the same track is repeated, but remastered, and with the missing music inserted.
So, like I said above, the ability to repair these things depends a LOT on the audio and what surrounds it. In this case, the repair was pretty much perfect.Last edited by johnmeyer; 23rd Jul 2018 at 19:11. Reason: clarification
Vob file skips every 33 seconds. Please help!
By adhouse13972 in forum DVD RippingReplies: 4Last Post: 29th Mar 2018, 21:23 -
fix 3gp file
By jamespoo in forum Newbie / General discussionsReplies: 5Last Post: 22nd Sep 2015, 21:14 -
Help Me Fix My Video File?
By antonyc in forum RestorationReplies: 3Last Post: 31st Mar 2015, 03:29 -
How do i make a mini mkv file?
By brotherhood1997 in forum Newbie / General discussionsReplies: 28Last Post: 27th Apr 2014, 21:40 -
Fix MKV file or converted M4v file - bad spot
By wdpcpa in forum EditingReplies: 2Last Post: 4th Feb 2014, 18:49
