Hello,
I've been using MKVToolNix for years and just recently upgraded to version 25. Is there a trick to getting a batch of videos to all join into 1 video? I've done this countless times before, but for some reason MKVToolNix won't allow me to join a dozen or so clips together into 1 video. To be clear, I can't seem to select "Default track in output" for more than 1 video - it just ignores the other dozen or so. If I select "Default track in output" to YES for any other clips, it automatically de-selects the other. WTF?!
Does anyone have any advice or ideas on how to get this to work? I'm just looking to remux a batch of videos without re-encoding or compressing.
[Attachment 46156 - Click to enlarge]
If you do it that way, I believe the result would contain the video and audio streams in parallel, not as a sequence (appended one after another). Concatenating may require a different workflow.
Open the first file in MKVToolnix. Right click and select Append.
[Attachment 46160 - Click to enlarge] -
is this reliable method to join m2v? / VOB losslessly through mkvtoolnix
By efc1978 in forum EditingReplies: 15Last Post: 15th Sep 2016, 22:57 -
MKVToolnix reduces overall bitrate of videos
By temp22 in forum Video ConversionReplies: 5Last Post: 13th May 2016, 13:06 -
How to join files with MKVToolnix
By yaston in forum Video ConversionReplies: 2Last Post: 5th Feb 2016, 08:22 -
SOME iPhone 6 Videos Show Up Upside Down In Windows 8
By hech54 in forum Portable VideoReplies: 23Last Post: 19th Apr 2015, 14:12 -
How can I play wmv and TS / MTS videos with Iphone 6?
By Stears555 in forum Software PlayingReplies: 7Last Post: 7th Dec 2014, 11:53
