I have a source where I am using TIVTC on it and it looks and works great as usual. I am having one particular problem with this source though. While it did its job really well overall, there are leftover combing/interlace artifact on certain moving things like blinking eyes for example. This also seems to be a problem when the entire screen shakes or moves quickly.
Does this have a special kind of pulldown setting or something needed done to it?
Here is the current script I am using.
LoadPlugin("C:\Program Files (x86)\MeGui\tools\dgindex\DGDecode.dll")
DGDecode_mpeg2source("C:\Users\User\Desktop\Encodi ng\DN\JPDVD\Disc 1\Episode 2\VTS_01_1.d2v", info=3)
LoadPlugin("C:\Program Files (x86)\MeGui\tools\avisynth_plugin\ColorMatrix.dll" )
ColorMatrix(hints=true, interlaced=true, threads=0)
LoadPlugin("C:\Program Files (x86)\MeGui\tools\avisynth_plugin\TIVTC.dll")
tfm(order=1).tdecimate(mode=1, hybrid=0)
crop( 2, 2, -4, 0)
LanczosResize(848,480) # Lanczos (Sharp)
Untouched DGIndex video sample can be found here
(File Removed)
If you use the script I made or the "tfm(order=1).tdecimate(mode=1, hybrid=0)" line of it, an example of what I am talking about can be seen on frames 433, 436, and frames 832-1105.
I guess this is just how the animation is. I checked the USA released Blu-Rays, the Japanese released Blu-Rays and the other set of DVD's I have and every single one of them have that same thing happening even on progressive Blu-Rays.
I guess I will just use Santiag(strv=0) to minimize them. It works well enough for me at removing most of them. -
The problem in frames 832-1105 is that it's not telecined, it's interlaced -- there is motion at every field. So it can't be inverse telecined. To reduce the combing you can lower TFM's cthresh parameter -- that cause the deinterlacer to kick in on those frames. That might create problems on other frames where the deinterlacer kicks in when it shouldn't. Or you can call vInverse() or QTGMC(InputType=3) after the IVTC to fix the combing. But again, this may create problems on other frames. So it would be best to use these fixes only on segments with problems.
Problem with Interlace+artifacts
By Kuronoe in forum Newbie / General discussionsReplies: 2Last Post: 8th Jul 2018, 13:45 -
Virtualdub: GUI convert PAL interlace to NTSC interlace
By kalemvar1 in forum Video ConversionReplies: 4Last Post: 23rd Sep 2017, 15:30 -
Why are interlace/combing artifacts only an issue on progressive displays?
By 90sTV in forum Newbie / General discussionsReplies: 12Last Post: 28th Jan 2017, 08:22 -
Rookie Help - Getting Rid of Artifacts/General Quality
By bschneider in forum RestorationReplies: 111Last Post: 11th Jul 2014, 13:08 -
Help getting rid of artifacts for the La liceale seduce i professori
By jondak in forum RestorationReplies: 23Last Post: 8th Jul 2014, 11:36
