The HDD in my father in laws Panasonic DMR-HW220 has failed big time. I have attempted to replace it with a 2TB drive, was a 1TB, recorder detects it and displays new hours of recording available, as opposed to 0:0, but the recorder indicates there is a problem not long after starting, may loose some recordings "OK", then launchs a repair / diagnostic routine. Next, or amongst the previous it displays "USB HDD may not have been disconnected properly". I have tried a 500GB drive, same problem, and around I go in circles. I had to mount the drives as USB HDD to format them then disconnected them using the menus availible.
I am thinking if I could get a copy of a service manual or a remote control key combo to get into the technicians service menu I would have more success.
Hoping some one can help this newbie.![]()
Haven't you tried installing a new 1 TB drive? It's possible the firmware is hard coded for that size.
Thanks JVRaines, actually purchased a 1TB drive today and are going through the slow process of formatting it in ex-Fat, hope it works.
Got a manual for the DMRHW220, but a Blue Ray DVD function is required in the remote key press combination. Key combination is (CH UP), (REC) and (OPEN/CLOSE) keys simultaneously for 5 seconds. Bugger.
I'll let you know it it goes.
KiwiinAussie -
KiwiinAussie
System for entry-level video editing
By vibrantvideo in forum ComputerReplies: 11Last Post: 2nd May 2016, 15:27 -
Error Code: C111.1 for Panasonic DVD DMR-EZ48V ??
By videoit in forum DVD & Blu-ray RecordersReplies: 1Last Post: 11th Apr 2015, 18:23 -
GoPro Hero (entry level) What format?
By micklos in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 9Last Post: 10th Apr 2015, 01:54 -
Panasonic dmr-e100h & panasonic dmr e700bd recorders - disc release problem
By nanirdjeff in forum DVD & Blu-ray RecordersReplies: 1Last Post: 5th Apr 2015, 12:59 -
Region Free code required for Audiovox DS2058A
By I_Am_Job in forum DVD & Blu-ray PlayersReplies: 2Last Post: 7th Feb 2014, 00:59
