  1. Hello,
    i have a decoding problem with RipBot 1.22.0. I get this error:
    [Attachment 46145 - Click to enlarge]
    Can someone tell me what the problem is?
    Mar 2008
    This often happens when you have a mix of 32 and 64 bit software in use at the same time.
    Check everything carefully
  3. I deleted all 32 bit software but i get the same error.
    I have tried another iso, because I get the error
    [Attachment 46148 - Click to enlarge]
    I once looked to see if the file exists, that's there.
    I also had the problem that I could not use the new RipBot at all. Every time I started it, nothing happened. In the task manager, I saw that the program is started briefly and then closed.
    When I copied only RipBot into the old folder, I was able to start it but now I get the errors.
    Dec 2010
    quebec
    or Avisynth+ (recently updated)
