what are the effects of reducing data rate..where can i learn more about this..and please suggest a tool/software so i can reduce video size by not loosing its quality.
Download some H.264 encoder base on x264 encoder , like Handbrake and use 1pass RF encoding (CRF encoding) . Set your video with different RF value, start with 18 I guess. You will see how it works, what size you are going to get. As you increase RF, quality will drop, but overall video size would drop too. This way you might find sweet spot that works for you. We all have different sweet spot for encoding video. It is not universal.
Another way to decrease videosize is to lower video resolution. -
What do you mean by data rate? If you mean bitrate, yes. Regardless of other properties:
This is in fact the definition of bitrate:Code:stream size = bitrate * running time
File size is the sum of all the stream sizes and a little overhead for the container.Code:bitrate = stream size / running time
Reducing file size for dvd
By midweb in forum Newbie / General discussionsReplies: 9Last Post: 8th Sep 2016, 21:49 -
MakeMKV reducing pixel size
By enonod in forum Video ConversionReplies: 4Last Post: 25th Oct 2015, 12:45 -
Reducing size of BluRay rips
By aye in forum Video ConversionReplies: 11Last Post: 16th May 2015, 05:43 -
Reducing dimension size
By rdeffley in forum RestorationReplies: 5Last Post: 20th Dec 2014, 14:03 -
MKVToolNix: Complete m2ts-to-mkv reduces file size - why?
By RogueComet in forum Video ConversionReplies: 1Last Post: 28th Sep 2013, 04:07
