Hello , recently i have a problem in encoding some videos and i use staxrip latest version to encode it and i tried ffmpeg in cmd too but i got nothing.
at the end of the encode , some videos is not synced with the audio , i tought the problem is the audio but after more trying i found out that the problem is the movie and the framerate then i tried with staxrip and i tried some custom framerate but i wasnt successful and i tried ffmpeg but i got this message "Past duration x.xxxxxx too large" for many times and in the main i got some errors in b frames but the movie and the audio was synced but i got some glitches in movie that after it you have to start movie 20 seconds after the glitch to watch it
*the source is fine , no glitches , no problem with the audio or video , everything is fine
please help me with that , thank you
Results 1 to 14 of 14
Provide audio duration and number of video frames... (so we can deduct video duration)...
Frame Count: 145340
Audio Duration from mediainfo:
Duration : 6116252.000000
Duration : 1 h 41 min
Duration : 1 h 41 min 56 s 252 ms
Duration : 01:41:56.252
Duration : 01:41:46:22
Duration : 01:41:56.252 (01:41:46:22)
General
Count : 325
Count of stream of this kind: 1
Kind of stream : General
Stream identifier : 0
Unique ID :
Unique ID :
Count of video streams : 1
Count of audio streams : 2
Video_Format_List : AVC
Video_Format_WithHint_List: AVC
Codecs Video : AVC
Video_Language_List : English
Audio_Format_List : AAC / AAC
Audio_Format_WithHint_List: AAC / AAC
Audio codecs : AAC LC / AAC LC-SBR
Audio_Language_List : / English
Complete name :
Folder name :
File name :
File extension : mkv
Format : Matroska
Format : Matroska
Format/Url : http://packs.matroska.org/
Format/Extensions usually used: mkv mk3d mka mks
Commercial name : Matroska
Format version : Version 4 / Version 2
Codec : Matroska
Codec : Matroska
Codec/Url : http://packs.matroska.org/
Codec/Extensions usually used: mkv mk3d mka mks
File size : 4883250132
File size : 4.55 GiB
File size : 5 GiB
File size : 4.5 GiB
File size : 4.548 GiB
Duration : 6116499
Duration : 1 h 41 min 56 s 499 ms
Duration : 01:41:56.499
Duration : 01:40:55:20
Duration : 01:41:56.499 (01:40:55:20)
Overall bit rate : 6386987
Overall bit rate : 6 387 kb/s
Frame rate : 23.762
Frame rate : 23.762 FPS
Frame count : 145340
Stream size : 2474239
Stream size : 2.36 MiB (0%)
Stream size : 2 MiB
Stream size : 2.4 MiB
Stream size : 2.360 MiB
Proportion of this stream: 0.00051
IsStreamable : Yes
Encoded date : UTC 2018-07-18 13:16:19
File creation date : UTC 2018-07-19 14:22:20.535
File creation date (local): 2018-07-19 07:22:20.535
File last modification date: UTC 2018-07-19 14:23:16.340
File last modification date (local): 2018-07-19 07:23:16.340
Writing application : mkvmerge v8.3.0 ('Over the Horizon') 64bit
Writing library : libebml v1.3.1 + libmatroska v1.4.2
Video
Count : 338
Kind of stream : Video
StreamOrder : 0
Unique ID :
Format : AVC
Format/Url : http://developers.videolan.org/x264.html
Commercial name : AVC
Format profile : High@L5.1
Format settings : CABAC / 3 Ref Frames
Format settings, CABAC : Yes
Format settings, RefFrames: 3
Format settings, RefFrames: 3 frames
Internet media type : video/H264
Codec ID : V_MPEG4/ISO/AVC
Codec ID/Url : http://ffdshow-tryout.sourceforge.net/
Codec : V_MPEG4/ISO/AVC
Codec : AVC
Codec/Family : AVC
Codec/Info : Advanced Video Codec
Codec/Url : http://ffdshow-tryout.sourceforge.net/
Codec profile : High@L5.1
Codec settings : CABAC / 3 Ref Frames
Codec settings, CABAC : Yes
Codec_Settings_RefFrames : 3
Duration : 6116416.000000
Duration : 1 h 41 min 56 s 416 ms
Duration : 01:41:56.416
Duration : 01:41:56.416 (01:40:55:20)
Bit rate : 6132482
Bit rate : 6 132 kb/s
Width : 3840
Width : 3 840 pixels
Height : 1608
Height : 1 608 pixels
Stored_Height : 1616
Sampled_Width : 3840
Sampled_Height : 1608
Pixel aspect ratio : 1.000
Display aspect ratio : 2.388
Display aspect ratio : 2.40:1
Frame rate mode : VFR
Frame rate mode : Variable
Frame rate : 23.762
Original frame rate : 24.000
Original frame rate : 24.000 FPS
Resolution : 8
Resolution : 8 bits
Colorimetry : 4:2:0
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8
Bit depth : 8 bits
Scan type : Progressive
Interlacement : PPF
Interlacement : Progressive
Bits/(Pixel*Frame) : 0.042
Delay : 83
Delay : 83 ms
Delay : 83 ms
Delay : 83 ms
Delay : 00:00:00.083
Delay, origin : Container
Stream size : 4688601509
Stream size : 4.37 GiB (96%)
Stream size : 4 GiB
Stream size : 4.4 GiB
Stream size : 4.367 GiB
Proportion of this stream: 0.96014
Default : Yes
Default : Yes
Forced : No
Forced : No
Color range : Limited
colour_description_present: Yes
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio #1
Count : 275
Count of stream of this kind: 2
Kind of stream : Audio
Stream identifier : 1
StreamOrder : 1
Unique ID : 11870632932990354875
Format : AAC
Commercial name : AAC
Format profile : LC
Codec ID : A_AAC-2
Codec : AAC LC
Codec : AAC LC
Codec/Family : AAC
Bit rate : 192000
Bit rate : 192 kb/s
Channel(s) : 2
Channel(s) : 2 channels
Channel positions : 2/0/0
ChannelLayout : L R
Samples per frame : 1024
Sampling rate : 44100
Sampling rate : 44.1 kHz
Samples count : 269726720
Frame rate : 43.066
Frame rate : 43.066 FPS (1024 SPF)
Frame count : 262580
Compression mode : Lossy
Delay : 0
Delay : 00:00:00.000
Delay relative to video : -83
Delay relative to video : -83 ms
Delay relative to video : -00:00:00.083
Video0 delay : -83
Video0 delay : -83 ms
Video0 delay : -00:00:00.083
Stream size : 144608923
Stream size : 138 MiB (3%)
Stream size : 137.9 MiB
Proportion of this stream: 0.02961
Title : 粤语
Default : Yes
Default : Yes
Forced : No
Forced : No
Audio #2
Count : 275
Stream identifier : 2
StreamOrder : 2
Unique ID : 1679659930148292742
Format : AAC
Format profile : HE-AAC / LC
Format settings : Implicit
Format settings, SBR : Yes (Implicit)
Codec ID : A_AAC-2
Codec : AAC LC-SBR
Codec : AAC LC-SBR
Codec/Family : AAC
Duration : 6116321.000000
Duration : 1 h 41 min 56 s 321 ms
Duration : 01:41:56.321
Duration : 01:38:42:19
Duration : 01:41:56.321 (01:38:42:19)
Bit rate : 62214
Bit rate : 62.2 kb/s
Channel(s) : 2
ChannelLayout : L R
Sampling rate : 44100 / 22050
Sampling rate : 44.1 kHz / 22.05 kHz
Samples count : 269729760
Frame rate : 21.533
Frame rate : 21.533 FPS (1024 SPF)
Frame count : 130303
Delay : 0
Video0 delay : -83
Stream size : 47565461
Stream size : 45.4 MiB (1%)
Stream size : 45 MiB
Stream size : 45.36 MiB
Proportion of this stream: 0.00974
Title :
Default : No
Default : No
Forced : No
Forced : No -
IMHO your video probably lost some video frames (corrupted during transfer/transmission) - to match your audio duration video framerate shall be 145340000/6116252 (i.e. 23.7629188594584 fps) but this is not standard framerate and decoders may try to "workaround" this framerate to match one of common (standard) framerates...
You can or try to find correct video source or you can try to change audio duration to match fake video duration - so for example you can change audio duration by resampling audio from 44100Hz to 43708.027767659Hz ((44100*(145340*(24000/1001))/6116252) and later set samplerate to 44100Hz - relatively easy by using one of common audio editors also SoX offer such functionality, then encode audio and mux with video (at the same you must set your video framerate to 24000/1001 i.e approx 23.976fps).
I think that glitch is related to corrupted video not framerate but...
I assume scenario was like this: someone used corrupted video and reencoded it (to fix issues?) thus perhaps some corrupted frames was discarded, now video duration with standard framerate is too short when compared with standardised framerates thus you need to use non standard framerates and this may introduce another group of issues. Changing audio duration looks like most appropriate approach.
Instead 24000/1001 you should be able to use 24 fps - audio resampling rate should be then 43664.3634042548Hz - this will even simplify further calculation and overall result should be still acceptable.Last edited by pandy; 19th Jul 2018 at 10:08.
thank you for your help, the source video doesnt have any glitch and the glitch appeared after the encoding video with 23.762 framerate , i have another question how can i calculate this ((44100*(145340*(24000/1001))/6116252 --> i got this 25,125.54777307767 ) or how to calculate the audio sample rate for syncing , imagine i have another video and the same problem i wanna learn the solution , thank you
Hm,
maybe it helps if you set input framerate of the video to 145340000/6116252 and output framerate to 24?
Audio can be stretched or squeezed with the help of the ffmpeg atempo filter, too.
E.g.:
ffmpeg -i audio.mp4 -filter: a "atempo=..." -y audio_new_length.mp4
Where ... = duration of audio in milliseconds/duration of video in milliseconds -
Perhaps - don't know your source but my educated guess lead me to conclusion this that it may be related to lost some frames.
Perhaps i've lost something during writing reply - apologies
Will try to make this simpler.
AudioSourceSampleRate (ASSR)=44100(Hz)
NumberofVideoFrames (NVF)=145340
FrameRate (FR)=24 ; (our assumed - new video frame rate)
AudioSourceDuration (ASD)=6116252(ms)
AudioTargetSampleRate (ATSR)=(ASSR*NVF*1000)/(FR*ASD)=(44100*145340*1000)/(24*6116252)=43664.3634042548Hz
(general idea is: ratio between real audio duration and calculated video duration is used to modify audio sample rate in a way that audio duration matching calculated video duration) - hope now it is without errors
More or less all automatic 'tempo' work on similar principle - idea is to play audio faster or slower depend if it longer or shorter than calculated video duration - of course this will shift frequencies proportionally but when change is not so significant this may be unnoticeable - to prevent frequency shift and change 'tempo' at the same time more fancy signal processing is required and frequently perceived result may be worse than small frequency shift. -
thanks again , i tried SoX but i got nothing because cant support m4a and tried ffmpeg too but i got the same result and it didnt support the 43664hz
i tried another way and i encoded the video in 24 fps and i changed the 44100hz to 48000hz and the both video and the audio was synced , how is that possible?
is there a relationship between the audio sample rate and the movie framerate , if the answer is yes how can i know this? means what is the sample rate with the 30 fps?
i'm confused right now and i cant resample it to test it and in the same i was successful with changing 44100 to 48000 , i wanna learn a stable solution to solve the problems
thank u -
Ok, SoX will not understand many codecs thus you need to use PCM (wav) and later re-encode wav to some usable form.
For SoX trick with sample rate may look like this:
But instead doing such things with SoX try to use ffmpeg (support SoX sample rate converter and by definition way more codecs)Code:@sox --buffer 131072 -S -V "%1" "%1.sox" rate -v -s -I 43664 @sox --buffer 131072 -S -V -r 44100 "%1.sox" "%1_.wav"
so i would give a chance to for example atempo=6116252/6055833.33333333 then audio duration should match video duration (24fps), for 23.976 it will be something like: atempo=6116252/6061889.16666667
Ok, now i've realised that we talking about Variable Frame Rate Video... have no clue how to deal with such thing - my first shot will be converting VFR video to CFR... - VFR is abomination in CFR world!
http://forum.doom9.org/showthread.php?t=173383
https://forum.videohelp.com/threads/378898-VFR-to-CFR -
MediaInfo has the tendency to report videos as VFR, if there is something wrong with the time codes.
At the following post, Jerome Martinez (developer of MediaInfo) explains, how it works:
https://sourceforge.net/p/mediainfo/discussion/297610/thread/b2a2708d/#8ba8
If there is a single time code difference at the beginning of a video, that differs from the rest, and all the others are equal, then it will be reported as VFR.
He also says, that MediaInfo reports an "Original frame rate", if there is an info in the fixed_frame_rate field.
Above an Original frame rate of 24 fps is reported. I would try to get the video back to that frame rate.
Maybe "-vsync 1" will help (it will duplicate missing frames making the video CFR). -
I don't use mediainfo (unreliable) - you could parse file trough ffprobe and analyse PTS delta (should be constant) - this will give answer for question if there CFR or VFR there...
Code:ffprobe -select_streams v -i %1 -show_entries "frame=pkt_duration_time" -pretty -print_format csv -of csv > "%~n1.csv"
SE Cyrillic Encoding problem
By AllaRosie in forum SubtitleReplies: 2Last Post: 6th Jan 2018, 10:17 -
x264vfw - problem with encoding
By Colek in forum Video ConversionReplies: 3Last Post: 13th Sep 2015, 04:19 -
5.1 AC3 encoding problem
By chazz spacey in forum AudioReplies: 12Last Post: 28th Dec 2014, 10:24 -
Problem : Encoding with RipBot264 1.17.5
By vivabarca in forum Blu-ray RippingReplies: 2Last Post: 15th Oct 2014, 17:43 -
text encoding problem
By afteryouwho in forum ffmpegX general discussionReplies: 2Last Post: 1st Aug 2013, 01:54
