I have a Pioneer DVD writer from An Apple MacG4 (DVR-103PA) which having spoken to Pioneer Technical support can be converted to work on a PC(however they will not diclose how) does anybody know how to do the converstion?? Many Thanks
Results 1 to 13 of 13
If installed in a PC it only works as a CD rom or DVD reader ONLY!! No matter what software is used the writing side is disabled according to PIoneer Tech support.
emu-
have you installed Nero (latest version if possible )to see if it sees the drive in DVD-R / -RW mode and is your aspi layer installed ? -
I think that the firmware for the apple drive is different from the firmware on the PC drives.... you might have to switch the firmware for it to work... if it refuses to take it check out over at http://forum.firmware-flash.com/index.php cause the admin overthere wrote a utility to force a firmware update onto the pioneer drives... of course this COULD ruin the drive and voids any warranty you have... but if its gonna work the most likely this is it.
Firmware on mac drive seams to be 1.22 if i try and flash v1.8 pc onto it it reports wrong kernal any ideas??
Save yourself the headache, get a combo Firewire/USB external enclosure and pop the drive in that. You should be good to go.
It's been tried in an external drive bay USB and that dont work either!!!
upgraded to ne w version of nere lasi night 5.5.8.0
now nero wont even open with dvd-rw connected!! but works fine if drive is removed!!!
what this kernal thing anybody know??? -
emu_p:
Personally your questions are a little over my head.... you might want to try the guys on the firmware forum... they seem to be into all the firmware stuff and would most likely have answers for you. -
i do not know that you can go from 1.22 to 1.8 direct, you might have to walk the flash up in successive builds for 1.8 to take effect, that and you are dealing with a OEM drive as they have different flashes for them then the retail drives.
Any body out there know if its possible to force a fireware upgrade!! Ie replace the Mac firmware with PC??
PAL -> NTSC DVD Writers?
By tac7 in forum DVD & Blu-ray WritersReplies: 4Last Post: 2nd Aug 2010, 21:34 -
Recommendations On Best Pioneer Blu-Ray Writers
By II AnDo II in forum DVD & Blu-ray WritersReplies: 1Last Post: 30th Dec 2008, 12:28 -
XP does not recognize my DVD writers as DVD writers thinks they're CD write
By steve1040 in forum DVD & Blu-ray WritersReplies: 5Last Post: 25th Jul 2008, 01:52 -
Better DVD Writers
By gameroftheuk in forum DVD & Blu-ray WritersReplies: 2Last Post: 30th Sep 2007, 13:51 -
Buying 2 SATA DVD Writers
By mis3 in forum DVD & Blu-ray WritersReplies: 3Last Post: 13th Aug 2007, 22:08
