Hello Everyone,
I was wondering if anyone knows the approximate relation between bitrate and quality(even though it is subjective) for x264 vs VP9 encoders at low bitrates, 400-900 kbps and 480p resolution videos.
I understand VP9 is better. But how much?
Thanks in advance.
Generally about half in the low bitrate scenarios. There is no right or wrong answer for these types of questions even though they get asked all the time. If you use x264 with the best settings and VP9 with the fastest/worst settings then the gap gets narrow.
With respect to bitrate and quality VP9 is more comparable to x265 than to x264.
You'll get acceptable results for 480p at a bitrate of 650 kbps (or lower) with VP9. It also offers a bitrate mode named "constrained quality" (see https://trac.ffmpeg.org/wiki/Encode/VP9). This is something not available in x264 or x265. It is a mixture of crf and 2pass abr encoding.
On the other hand:
- VP9 encoding is much slower than x264 (and also slower than x265) -> that's the biggest disadvantage and probably the reason why it's not used by many sites
- Documentation is poor as it's not used that often
- It's not supported by IOS
- It's less stable than x264, tending to produce problems where x264 works fine -
The problem with VP9 is megablock blurring of objects (grass and foliage is converted into a large green square).
Hybrid(Windows/Linux/Mac): Input -> x264/x265/Xvid/VP8/VP9
By Selur in forum Video ConversionReplies: 2394Last Post: 5th Jan 2026, 10:52 -
VP9 on Youtube
By newpball in forum Video Streaming DownloadingReplies: 4Last Post: 1st Apr 2015, 19:27 -
X264 is better than VP9! Sicentific test by real scientists!
By Stears555 in forum Video ConversionReplies: 3Last Post: 19th Apr 2014, 13:28 -
Where can I find VP9 encoders or a transcoder software which has VP9 too?
By Stears555 in forum Video ConversionReplies: 8Last Post: 10th Sep 2013, 16:51 -
anyone know of any gui's that use vp9?
By deadrats in forum Video ConversionReplies: 28Last Post: 4th Aug 2013, 03:41
