I have an totmc EZ-Cap, to go from VHS TO muh file, but I have a problem with the sound match the spoken words? It seems to be a few seconds off. Is this a software issue or an EZCap issue? How do I solve it? What type of capture device would you recommend? John![]()
Most "EZ CAP" devices are fake, counterfeit knock-offs.
Stop trying to capture to MKV. Try capturing a lossless codec first.....then encode that file to whatever you need. -
What capture devices aren't take? How much should I expect to pay for a decent one? Lossless codec (avi?)?
"avi" is not a codec. The codecs most often used for lossless capture are huffyuv and Lagarith, some use UT Video codec. Huffyuv uses less CPU power.
EZCap, EasyCap, aka "Easy-Crap" (a nickname that should tell you something) aren't so great. A similar but better long-time budget favorite is Diamond Multimedia's VC500 USB.- My sister Ann's brother
Inserting one .mkv file into the middle of another .mkv file
By Cinderwolf in forum EditingReplies: 4Last Post: 29th Dec 2017, 17:48 -
Merging MKV extracted files to playable MKV video file
By deepfrayder in forum EditingReplies: 9Last Post: 13th Dec 2017, 00:17 -
Capturing VHS to digital file format in 2016
By Cygnus111 in forum Capturing and VCRReplies: 13Last Post: 2nd Apr 2017, 07:17 -
VHS to PC capturing help please, screen flickers only on capture not on vhs
By Rdakin7593 in forum Capturing and VCRReplies: 7Last Post: 25th Aug 2015, 12:52 -
Please help me burn in subtitles to MKV rip file of blu ray (mkv/handbrake)
By jimbanville in forum Blu-ray RippingReplies: 1Last Post: 23rd Jan 2015, 09:45
