  1. Hi,
    i installed avisynth 2.60 on windows 7 in a virtualbox. also avspmod and the requirements for lsmashsource ms visual c++ 2015 (also 2013). but when i load a avisynth script to avspmod i cant open the video. the error is something like "missing library". ffms2 works. how can i check whats missing? i think al is installed?
    valit
    Aug 2013
    Central Germany
    You can use AVSMeter to check if any AviSynth plugin misses a DLL. But AvsPmod may also need some runtimes.
    AVSMeter -avsinfo -log
    "Something like" is usually not a sufficient problem report. I would prefer error messages quoted as exactly as possible. If it appears in a dialog window, try to press Ctrl+C, it may copy its content to the clipboard, so you can paste it into a QUOTE or CODE here.
  3. ok i'll test avsmeter.
    but what runtimes does acspmod need? i never installed something when i used it. ffms2 works, only lsmashsource makes problems.
