A quick question about playlists. The other day I created a playlist of video cuts, saved it, then later on loaded and started playing it.
While it was running I manually added a couple of tracks in the middle and moved a couple of existing tracks around. However, playback instead stuck to the original order and skipped the added tracks until later.
I expect it to accept the new order immediately after the changes and play the list as displayed. Am I missing a setting?
I see references to the playback queue, and I now assume that a playlist that is loaded gets pushed to this queue, and subsequent changes do not? Is there an easy way to access this queue?
Results 1 to 1 of 1
PotPlayer: disable autoplay next in playlist
By madbucky in forum Software PlayingReplies: 3Last Post: 12th Mar 2023, 00:28 -
Potplayer playlist bug/problem
By AsadAlrafidain in forum Newbie / General discussionsReplies: 0Last Post: 6th Jul 2018, 05:51 -
PotPlayer: Advancing the Playlist issue
By lemings in forum Software PlayingReplies: 1Last Post: 22nd Jun 2017, 14:40 -
Having an Add To Potplayer Playlist option come up when right-clicking?
By stevaside in forum AudioReplies: 6Last Post: 23rd Jan 2016, 00:04 -
potplayer add the playlist shortcut ?
By albatros44 in forum Software PlayingReplies: 0Last Post: 11th Aug 2015, 14:13
