I did post here before and got briliant help but cant seem to find last post so made a new post
I have this script for making movie clips louder. but just tried a short clip and get this error, would anyone know why this is the error below. it seems to be something about timestamp
Code:Input #0, avi, from 'C:\ffmpeg-3.4-win64-static\bin\movie.clip.avi': Metadata: encoder : MEncoder Sherpya-SVN-r33488-4.2.5 Duration: 00:43:09.34, start: 0.000000, bitrate: 1128 kb/s Stream #0:0: Video: mpeg4 (Advanced Simple Profile) (XVID / 0x44495658), yuv420p, 624x352 [SAR 1:1 DAR 39:22], 988 kb/s, 23.98 fps, 23.98 tbr, 23.98 tbn, 23.98 tbc Stream #0:1: Audio: mp3 (U[0][0][0] / 0x0055), 48000 Hz, stereo, s16p, 127 kb/s Stream mapping: Stream #0:0 -> #0:0 (copy) Stream #0:1 -> #0:1 (mp3 (native) -> aac (native)) Press [q] to stop, [?] for help Output #0, matroska, to 'movie.clip_dynaudio.mkv': Metadata: encoder : Lavf57.83.100 Stream #0:0: Video: mpeg4 (Advanced Simple Profile) (XVID / 0x44495658), yuv420p, 624x352 [SAR 1:1 DAR 39:22], q=2-31, 988 kb/s, 23.98 fps, 23.98 tbr, 1k tbn, 23.98 tbc Stream #0:1: Audio: aac (LC) ([255][0][0][0] / 0x00FF), 48000 Hz, stereo, fltp, 192 kb/s Metadata: encoder : Lavc57.107.100 aac [matroska @ 0000016bfaac89c0] Timestamps are unset in a packet for stream 0. This is deprecated and will stop working in the future. Fix your code to set the timestamps properly [matroska @ 0000016bfaac89c0] Can't write packet with unknown timestamp av_interleaved_write_frame(): Invalid argument [matroska @ 0000016bfaac89c0] Can't write packet with unknown timestamp Error writing trailer of movie.clip_dynaudio.mkv: Invalid argument frame= 241 fps=0.0 q=-1.0 Lsize= 1kB time=00:00:10.01 bitrate= 0.7kbits/s speed= 82x video:631kB audio:0kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: unknown [aac @ 0000016bfaadcce0] Qavg: nan Conversion failed! Press any key to continue . . .
and this is the audio script
Code:@setlocal @echo Audio processing, video is copied losslesly @rem folder where ffmpeg.exe is located @set FF=C:\ffmpeg-3.4-win64-static\bin @set PATH=%FF%;%PATH% @set filename=%~1 @rem audio bitrate @set ab=192 @set aproc="pan=stereo|FL < FL+1.414FC+0.5BL+0.5SL+0.25LFE|FR < FR+1.414FC+0.5BR+0.5SR+0.25LFE,dynaudnorm=p=1/sqrt(2):m=100:s=20" @ffmpeg.exe -hide_banner -v 32 -stats -y -i "%filename%" -c:v copy -af %aproc% -c:a aac -b:a %ab%k -f matroska "%~n1_dynaudio.mkv" @endlocal @pause
Also I have another error on another movie clip too
Code:Audio processing, video is copied losslesly Input #0, matroska,webm, from 'C:\ffmpeg-3.4-win64-static\bin\test.clip.mkv': Metadata: COMPATIBLE_BRANDS: isommp42 MAJOR_BRAND : mp42 MINOR_VERSION : 0 ENCODER : Lavf57.83.100 Duration: 00:21:50.77, start: 0.000000, bitrate: 988 kb/s Stream #0:0: Video: h264 (Main), yuv420p(tv, bt709, progressive), 1280x720 [SAR 1:1 DAR 16:9], 29.97 fps, 29.97 tbr, 1k tbn, 59.94 tbc (default) Metadata: HANDLER_NAME : ISO Media file produced by Google Inc. DURATION : 00:21:50.765000000 Stream #0:1: Audio: aac, 44100 Hz, stereo, fltp (default) Metadata: HANDLER_NAME : ISO Media file produced by Google Inc. ENCODER : Lavc57.107.100 aac DURATION : 00:21:50.766000000 Stream mapping: Stream #0:0 -> #0:0 (copy) Stream #0:1 -> #0:1 (aac (native) -> aac (native)) Press [q] to stop, [?] for help Too many packets buffered for output stream 0:0. Conversion failed! Press any key to continue . . .
	You can add '-fflags +genpts' to command line but not sure if this will work and solve issue with your source.
 Not sure if this is not an issue related to codec and container then this filter may be necessary https://ffmpeg.org/ffmpeg-bitstream-filters.html#mpeg4_005funpack_005fbframes - some of bitstream filters are invoked automatically if necessary, not sure how with this case.Code:@ffmpeg.exe -hide_banner -v 32 -stats -y -fflags +genpts -i "%filename%" -c:v copy -af %aproc% -c:a aac -b:a %ab%k -f matroska "%~n1_dynaudio.mkv" Last edited by pandy; 15th Jul 2018 at 04:56.
	well it seems to have fixed it thanks again
 Where would I need to place this line in the script anyway
 ffmpeg -i INPUT.avi -codec copy -bsf:v mpeg4_unpack_bframes OUTPUT.avi
	this bitstream filter can be placed after input and before output however not sure if AVI is a good container for it (main purpose of this filter is to unpack frames packed for AVI container due of AVI container limitations). Honestly i don't recall this kind of problems from XVid/Divx files...
  ffmpeg Scaling ProblemBy Mardon in forum Video ConversionReplies: 2Last Post: 26th Feb 2018, 18:55
  The problem with converting ffmpegBy Jamaika in forum Newbie / General discussionsReplies: 2Last Post: 30th Sep 2015, 14:02
  ffmpeg mux problemBy hippy2000 in forum Video ConversionReplies: 23Last Post: 2nd Mar 2014, 18:54
  FFmpeg muxing problemBy w2kpro in forum Newbie / General discussionsReplies: 21Last Post: 26th Oct 2013, 05:46
  problem with ffmpeg.exeBy euphonic in forum Video ConversionReplies: 4Last Post: 9th Oct 2013, 13:00
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
